Eibach Pro Truck kit - springs and shocks
love the ride and look - sits perfectly level
On 5/23/2019 at 11:53 AM, Pivot said:
I'm learning as I go. If you are going 2 1/2" up front, at least be prepared to replace UCA's. Some guys say they are fine and wheel size and offset can come into play. I do know one thing. I ordered the 2" rear spacer from Motofab. Pulling the stock block and replacing with 2" should net you 3/4 inch lift in rear. I already have the Bilstein 5100's in my garage. They allow stock up to 1" lift. $70 each on Amazon. They would be nice upgrade over Ranchos anyhow and won't break the bank.
Most say if you go much over 2" up front, you "COULD" have poor angles on UCA . This is usually disputed back and forth. I went with the new Struts and Coils up front from Bilstein.Model #6112. I should get 1 3/4 up front on max setting #4. Bilstein said they are designed with stock UCA in mind. Both shocks and coils run between $600-$700. You could also look at the adjustable 5100's up front at about $90 a pop. Get the same lift. You reuse stock coils to keep down price point.
I'm waiting for the block to arrive from Motofab and then I have to pick out new wheels and bigger tires. Wait till you get into wheels, offsets, backspacing, various tire sizes..
Yes you will need a Front end Alignment anytime you change things up front. Wheels, tires, struts what have you. GL
Well I just ordered the 2-1/2" Front and 2" rear from MotoFab.
Hopefully install goes ok and no rubbing.
If anyone has any pointers on install, other than what most videos show, let me know as it would be greatly appreciated.
Thats what i have, along with readylift ucas. Have had no issuesbbb60b3b8e4666ce2886e03eb79fc444.jpg08595da76a64308f4eefe2c949680161.jpg
Sent from my SM-G973W using Tapatalk
I didn’t get UCAs, I guess I am hoping that I’m ok with the stock stamped ones. Truck looks nice!
What wheels/tires do you have? I have an 18' with a Motofab 2.5" up front and 2" rear block. I also have 20" wheels and 275 width tires, I get some UCA rubbing at full lock. I didn't have any rubbing at all when I had my previous 1.5" level, so I can only assume the extra inch caused the rubbing..
I have the stock 20” wheels and tires. I should have the kit this week and going to try to find time this weekend to install. I will report back with the outcome.
I have basically the same setup that you intend to install on stock 20” with 285x60R20 Toto Open Country RTs and had to add RC 1/4” wheel spacers to stop the rubbing on UCAs and sway bar.
Are they from Kansas?  :P
I'm still learing the offsets and trying to figure tires and rims. Assuming stock rims and guessing you have +27 offset, that tire moved the inner sidewall exactly .24 " closer to suspension and frame. I might be wrong and others with more experience please chime in, but... If you moved to a +20mm offset, I don't think you would need the spacer. A +20 offset would move the outer sidewall .08 away from suspension with that tire. You did increase the total diameter of the tire though significantly and that could present issues. Total tire diameter would increase from 100.2 up to 105.1  Truck looks nice with tires and level.
Ah, if only someone would make replica wheels with more accommodating offsets. Many like the stock wheels, especially the snowflakes.
And your math works, but tire manufacturers aren't quite that precise. One brand 285 might be 283,whereas another might be 286. Then there's the difference in how aggressive the sidewall lugs are. Lots of variables.
Edited by MBSierra17
Does anybody know what the differences are between a top mount and bottom mount spacer to level?
The top mounts seem to be more expensive and may require cutting the length of the top shocks bolts from what I can tell, so are there any positives to going with the more expensive top mounts?
What bug deflector do you have?  That is the style I am looking for and have the same color truck.
Got the MotoFab 2.5” front/ 2” rear installed last weekend. Install went pretty good, only about 4 hours complete. No rubbing, seems to ride same as stock. Thanks to those who provided input!
  • Like 4
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
