23 hours ago, acinquegrana said:
What kind of tires?
Sent from my SM-G950U using Tapatalk
Atturo trail blade mt
33x12.50r22
Not sure what mine has as I bought it how it is for really good price with wheels, so I been told it’s a 2in leveling kit but idk it still sits alil higher then my friend’s truck here couple pictures of it would like to know what it has maybe one of you can help me figure it out. It’s on 20s 20x12.5 33s
Edited by Frankielozano214
It's finally my turn to have something to post in this thread.
RC 2" Leveling Kit
Fox Performance 2.0 Shocks
Cooper Discoverer AT3 XLT  285-75R18
Edited by theJman
.. well that looks like a 2" block in the back.. can't see the front ?
33x12.50 R22 Nitto Ridge Grapplers
OEM Wheels
2" wheel spacers
2.5" SuspensionMaxx front leveling Kit
Had to do minor plastic and metal trimming on the back inside of both front fenders to alleviate rubbing.
789685466_IMG_9823(Medium).thumb.JPG.1ffeca2c948e0dc7c25c3b9b0732eda8.JPG17113590_IMG_9824(Medium).thumb.JPG.aef0cbb8927a4d61cfb97c1879eff60d.JPG1849074072_IMG_E9825(Medium).thumb.JPG.dd7be79af7e27d38e8731d647f2eff92.JPG1919981427_IMG_E9826(Medium).thumb.JPG.b1968767450743140d6cd16f3ed6de7a.JPG1442393638_IMG_9836(Medium).thumb.JPG.95e86f7fe954a8b244a28a208d42a215.JPG
OEM Wheels
2" wheel spacers
This looks simply amazing... It's how they should have built the truck in the first place...
Edited by Matt_UKTX
Here is my 17, 2 inch MotoFab leveling kit with 275/60/R20 tires. Rides as issued
Edited by Passport
So I've read a good 70% of this very informative thread. There is so much information that I'm having trouble deciding what I want. I was thinking motofab 2.5 with a 1 inch lift in the rear(2.25in block). I'm hoping that level front to back...or readylift 2.25 with a 2in rear block...and do I need control arms??? Is it worth it?
70% of 487 pages?  dang, that's impressive!
RC 2" Leveling Kit
812800137_GMCSierraBeforeLevelingandTires1.thumb.JPG.92130ba4c3cafd10d470665e6e7c4d6a.JPG
15836674_GMCSierraBeforeLevelingandTires2.thumb.JPG.e43ae90d59c4a4e5cbdb3d5b6034fae7.JPG
431011211_GMCSierraAfterLevelingandTires2.thumb.JPG.18dcd36f6abbf8f1230752c784b5677a.JPG
Good looking truck, how do you like the Cooper XLT and what are your initial thoughts on them?
Sent from Above
Do coil overs, you’ll be thankful you did.
Sent from Above
So far, so good.  I have almost 600 miles on them now but that's all been in the dry; for whatever reason, when it's rained in NJ I've either been working from home that day or it was a weekend and I wasn't heading out.  My research suggests they're good in the rain but I don't know myself yet.  Looking at the number of wheel weights it seems like they might have been a challenge to balance, but they ride good.  I get a little hum that starts about 40 but by 50-55 the road and wind noise drowns it out.
I wish I could tell you how much of the ride difference is due to the tires and how much is the shocks but unfortunately I can't.  Fox told me not to put on the front ones until I did the leveling because they would likely bottom out so tires and shocks were done at the same time.  I can tell you the combination makes the truck so much more stable going over rough roads.  The factory Rancho's seemed to lack sufficient damping so ruts and uneven surfaces - especially on the highway - would unsettle the truck.  The suspension movements were very sharp and exaggerated.  There's one patch on my commute home that really used to be a white-knuckle affair.  It's a slight bend in the road with a bridge and a dip on the left side (the right side has no dip).  With the original Rancho's and Michelin's the truck would become difficult to keep in the lane as you hit the expansion joints and that dip during the curve, even if you were only going 70.  Now, at 75 the truck barely reacts. For me that's a huge update, there's no more WTF moment when I get to that area.
One thing I do notice though is more back-and-forth wobble in the steering wheel when hitting bumps and potholes.  The truck did that before but with the bigger/heavier tires and firmer shocks it's now pretty obvious.  A steering stabilizer is in my future.  For me that's an acceptable trade-off for what I gained.
Edited by theJman
So far, so good.  I have almost 600 miles on them now, but that's all been in the dry; for whatever reason, when it's rained in NJ I've either been working from home that day or it was a weekend and I wasn't heading out.  All I've read about them says they're good in the rain but I don't myself yet.  Looking at the number of wheel weights it seems like they might have been a challenge to balance, but they ride good.
I wish I could tell you how much of the ride difference is due to the tires and how much is the shocks but unfortunately I can't.  Fox told me not to put on the front ones until I did the leveling because they would likely bottom out so tires and shocks were done at the same time.  I can tell you the combination makes the truck so much more stable going over rough roads.  The factory Rancho's seemed to lack sufficient damping and ruts and uneven surfaces - especially on the highway - would unsettle the truck.  The suspension movements were very sharp and exaggerated.  There's one patch on my commute home that really used to be a white-knuckle affair.  It's a slight bend in the road with a bridge and a dip on the left side (the right side has no dip).  With the original Rancho's and Michelin's the truck would become difficult to keep in the lane as you hit the expansion joints and that dip during the curve, even if you were only going 70.  Now, at 75 the truck barely reacts.  For me that's a huge update.  Now there's no more WTF moment when I get to that area.
One thing I do notice though is more back-and-forth wobble in the steering wheel when hitting bumps and potholes.  The truck did that before but with the bigger/heavier tires and firmer shocks it's now pretty bad.  A steering stabilizer is in my future.  For me that's an acceptable trade-off for what I gained.
You did do an alignment after the level, hopefully
Sent from Above
    • I’m out of ideas on this truck. 2020 Silverado 1500. 5.3 135,000 miles. Has a p0308 and p050d codes. Smokes From exhaust when cold. Compression test passed. New plugs, wires and coil on cyl 8. Same issue. New coil on 8, no change. Replaced injectors, no change. Bore scope showed oil pooled on the piston after sitting overnight. Pulled head and had machine shop check it out. No cracks. Stem seals looked good, replaced anyways. He also ground valve seats. Put it all back together and still have the same issue. Bore scope shows oil on the piston again. Leaning towards maybe a cracked ring but unsure. Cylinder looked good when the head was off, no scoring or scratches. Any ideas on what else I should look for?  Appreciate the help
    • Just want to make sure it is covered by Special Coverage N232395310 Evaporative Emission Purge Pump 2021 Silverado 1500 Custom 2.7L L3B ~100k miles I'm getting DTCs P146B and P146F. VIN 3GCPWBEK2MGxxxxxx   I spoke to a person that works at GM and he said it is not covered after checking my VIN.   Is there anyone here who currently works for a GM/Chevrolet dealership and has access to GM Global Warranty Management / Investigate Vehicle History who could explain how the VIN eligibility is determined?   thank you
    • Thanks for all that information, I might purchase one and see if it will work for me, if not they may let me return it! Yes for sure the tires are definitely within limit for my truck empty, and when I do tow I'll definitely make sure to raise the rear psi for the amount of weight that's going to be on it.
    • Yes exactly, more and more these days people/companies are afraid of liability issues so its easier just to say no rather than risk putting their neck on the line.    I will say with the Autel unit or when I used it last year on my truck, it wasn't like I could choose the 2025 model year or even the 2024 model year as that option was not there to manipulate the placard pressures but had to go back to 2023 or there abouts and then it showed up as an option, odd but that was how the software was then and I can't say one way or the other now as they throw out updates every so often. I still would talk to your tire dealer though to start with and they may do it for nothing but also they may have a comment on a better unit to purchase. All I know is that one of the large tire shops in my area happens to use these Autel units for their use and set them up to use the wifi and all of that jazz for constant updating because each tire tech has one handed to them by the shop but I just plugged it into my laptop to update it and yes if one is bought it has to be registered so you can get the link to do updates and then the unit has to be updated before its even used. I am not at all techy so it took me a bit but anyway just a heads up for anything you buy, most likely it will need to be connected to a computer to access the internet to have it updated to the latest software version before you can put it to use.   If your truck is near empty, those tire pressures you listed are a very safe upper range pressures to carry the weight, both the front and rear as I know they could be run lower yet with an empty truck. And if its a trailer and not some motorcycle your going to strap onto the front of your truck on a rack, you shouldn't have a need to inflate your front tires if your at 55 front already, its the rear ones that would need more air if you have much hitch weight.
    • Thank you, I'll check that Autel scanner out and see if it will work for me! Ya I can see GM's point of view if they lower the psi set value for someone and the person sell's the truck and the new owner puts the factory tires back on then their could be liability issues cause the psi warning light wasn't coming on when the tires were under inflated for towing their load and then it might be able to be traced back to GM lowering it.
