So my first problem with my set-up. My driver side tire rubs UCA when turned to right at full cock. Left side fine. Ordered 1/4" spacers for now. My local shop guy told me running stock wheels with aftermarket UCA causes the rub sometimes?
Anyone????
Well had to do it. Stock wheels wouldnt stop rubbing at full cock to the right with new Freedom UCA's. Bought some KX offroad (makers of XD) 18x9 with -12 offset wrapped in 265/65-r18 Falken Wildpeak AT3. 33x12.5r18 dont fit. I get the rub on rear fender well and im not cutting or banging my new truck. Ill wear these out then raise my truck another inch and try for 33's next time. Gonna install some lighting next.aaed7a2bcb41944d59cb532e98dd271b.jpg6b6caf92f3e7f53edb905f2b845052af.jpg47db913f3200cf5dca3aff0fdf47d23b.jpg
On 9/3/2019 at 1:24 PM, alodawg26 said:
Hello All. I have been searching for a few days now, but haven't found exactly what I'm trying to do. I have a stock suspension 2017 Silverado z71. I'm looking to level it out and improve the ride, but still want a small amount of rake for when I tow/haul. This is my daily driver, and don't do a lot of off-road driving. Most of my driving will be on the highway in the Midwest, meaning horribly maintained asphalt. I'm considering:
Bilstein 5100 adjustable on the next to highest (3rd?) setting OR, do I want to do a coilover assembly replacement? I haven't seen anything on these yet: https://www.roughcountry.com/gm-leveling-struts-500063.html?find=2017-chevy-silverado-1500-4wd-374174. Has anyone installed/used these? If so, how is the ride quality of these?? I've seen nothing on the N3 shocks. $329 seems pretty cheap especially when comparing against the Fox and Bilstein 6112. If I go the coilover and shock replacement route, should I just save my money and buy a Bilstein or Fox?
Thanks for your help and advice.
What did you wind up going with?
Anyone????
Hate to hear that.  Unfortunately, it’s what I’ve heard a lot of.  Did you get the rub  before or after the new tires?  I’m told anything over 11.5” wide will rub with the factory wheels.  Wondering if I stayed at 11” if they’d still do it. If you did get the rub before new tires, what did you have on it previously? On a side note for anyone interested, I talked to JBA Offroad today inquiring about their arms.  For now, they make nothing compatible with the stamped steel or aluminum UCAs, only the cast steel,  but they are in the works.   However, he couldn’t tell me an expected release date.  If you look at the design of their arms, they are built with a slight bend in them he said that corrects this issue everyone’s having with rubbing.  Too bad they aren’t available yet?.  At any rate, doesn’t do us much good for now, but hopefully they’ll get them out sooner than later.
Hate to hear that.  Unfortunately, it’s what I’ve heard a lot of.  Did you get the rub  before or after the new tires?  I’m told anything over 11.5” wide will rub with the factory wheels.  Wondering if I stayed at 11” if they’d still do it. If you did get the rub before new tires, what did you have on it previously? On a side note for anyone interested, I talked to JBA Offroad today inquiring about their arms.  For now, they make nothing compatible with the stamped steel or aluminum UCAs, only the cast steel,  but they are in the works.   However, he couldn’t tell me an expected release date.  If you look at the design of their arms, they are built with a slight bend in them he said that corrects this issue everyone’s having with rubbing.  Too bad they aren’t available yet[emoji57].  At any rate, doesn’t do us much good for now, but hopefully they’ll get them out sooner than later.
Was getting the rub with stock wheels and tires. Went with18x9 -12 offset wheels and 275x65r18 tires...no rub anymore. 32.3" tall and 11" wide.
Sent from my SM-T580 using Tapatalk
Anyone on here ever tried 285/70/18 tires with a 2" rough country level on a 2014 chevy Silverado? My 275/70/18 toyo open country m/t's have 55k miles on them and its time for a new set. I'm tempted to try the 285/70/18 in nitto ridge grappler. Anyone have this set up? If so, any rub and how much? Attached is a pic of my truck with the 275/70/18 toyo open country m/t (33.6 x 11) with no rub.
I have a 2" RC level and 285/70/18's on stock rims and there has been no issues thus far (a little over 3k miles since everything was installed).  My truck is a 2018 2500HD though so it's not apples-to-apples.
I wouldn't expect them to rub on a 2500. Thanks for the comment though!
Was told that size is hard to get.
In nitto ridge grapplers?
Guys run 295/70/17s so dont see how that size would rub if those dont
I'm gonna try it and see. It still blows my mind I've yet to find one single person with the exact setup I'm asking about. Maybe ill be the first with a 2" RC level and 285/70/18 nitto ridge grapplers lol
I’ve never even heard of that size before. That being said, they’re very similar to a 285/75/17 and those will for sure rub on a 2” level. It will require some trimming but it’s doable
Just that size in general. I wanted that size. Told i had to wait to get. I dunno didnt want to wait.
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,298 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
