On 1/2/2020 at 6:39 PM, BassCatsBeerandDeer said:
Ladies and Gents,
Wanted to give a big shout out to everyone who contributes to these forums as well as thank you for those who posted there mods and set ups. A ton of my questions regarding my truck were solved right here as well as helped me decide on my suspension route! Hopefully my contribution will assist another curious soul like myself as to what they can run for performance, clearance, looks and minimal costs!
2017 Z71 5.3 with STAMPED control arms.
- Swapped my rough country level blocks (2'" level) for a 4 pack of Bilstein 5100s. achieved 1.8" of level in the front and retained the same height in the back so a slight level with some rake.
- Swapped my stock 275/55/20 Goodyear SR-A and rims which equates to a 31.9"  tall and 10.9" wide tire for a set of Nitto Ridge Grapplers in 33/12.50/18's and Fuel Assaults 18x9 -12 offset, putting me barely an inch outside the wheel well
- To begin with, I trimmed the felt liner maybe 2-3"s and slightly bolted it back to remove ANY rub, as well as slightly trimmed the front of the air dam to ensure zero rub, which was achieved successfully!! I have excellent clearance at all angles, zero rub on any components including my dreaded UCA problem even while running through my deer hunting field.
- The Bilsteins and NIttos feel BadA$$ for lack of better terms, much much more smoother than my Ranchos and I feel the 12.50s gripping much better than my 10.9s. Not to the point where it feels laggy or bogged down but much more comfortable and smooth. The shocks are night and day, seriously! As far as acceleration goes, I noticed zero difference when I stomped it to hop on the freeway, as well as saw minimal loss in MPGs. These are all concerns that I had when deciding with a bigger tire set up.
- For those who want to run a nice big mean tire with a slightly aggressive offset and look, this is an ideal set up for cost and performance with minimal trimming and mods. I'm sure I missed  something here so please feel free to ask questions or request any pictures of mods or gear and thanks again guys for contributing and answering the questions I had!
Bilstein 5100 shocks alone will raise our trucks 1.8” in the front?
2018 Chevrolet Silverado LTZ with 295/55/20 Nitto Ridge Grapplers and a 2 inch rough country leveling kit. I know a lot of people like aftermarket wheels but i love the stock LTZ 20s. Thinking about possibly doing the 2.5 kit on the front and the 1 inch block in the rear.
Any rubbing issues at all? I played it safe with 275/55/20 with 20x9 wheels with a 0 offset and don't have much room to spare when turning on level ground. Especially don't want to be in the woods somewhere end up tearing the wheel wells apart once the suspension has some articulation to it but think I could have gotten away with a little bit bigger tire with a RC 2 inch leveling kit installed
Some times at full turn to the left it will rub but it has to be fully turned. I never really have it locked anyways. I am sure the two inch leveling kit helps with that. I have been really pleased with the set up.
Have a question guys. 16 Silverado 1500 , planning to put on motofab 2.5 level, looking into ready lift control arms , anyone running 275/70r18 on stock 18” rims have rubbing issues?
Also ready lift or motofab control arms? Motofab has been out of stock for a while though
I have a 2017 1500 4x4 i just purchased and it has bout 3 1/4 inches from front to rear, measuring from center of wheel to fender well. Way too much rake for my liking, it has factory 22" wheels. Just want to level front and put wider tires on or possibly switch to 20" wheels and tires? Any suggestions on which leveling kit and how much bigger can I go on tire size for both scenario's? Tire size on it now is P285 45r22. thanks in advance
Saw this today. Couldn’t tell what size level but had 285/65r20 K02’s. I didn’t see markings on the UCAs but it did have the fender liner zip tied back. Was a sharp truck.
2018 GMC Sierra double cab, 4x4 elevation. I put a 2” rough country level on the front and
275 55r20 (stock size) Nitto Ridge Grappler tires on. I didn’t want to get crazy with mods while the truck is under warranty and I’m happy with how it looks!
Running  Rough Country 2.5" front/1" rear kit 275/70/18's. Wheels are OE Spec. No rub but it is close.
Stock control arms? Did you do anything with front or rear shocks ?
From what I have read as long as you stay in the 2.5" and under you are fine with stock arms. The 3" messes with angles. Stock shocks front and rear.
My Leveling kit story.
The left rear shock on my 2017 Sierra SLT Z71 was covered in oily dirt from a slow leak. I decided to solve that problem by upgrading to the Rancho QuickLift 2" struts (P/N RS999198) for the front and the Rancho RS9000XL 0" shocks (RS999198) for the rear. I bought all of it from Rock Auto. $569 total.
The Original GM Rancho Shocks and Struts, aside from one of them leaking, were OK but I felt they could have been firmer.
I wanted to post here to add some information on what was involved in the install.
The new Rancho shocks and struts have an adjustment knob with 9 settings. I watched some youtube videos of people complaining about the adjuster knobs freezing up over time. I took the adjusters (they are a red plastic) off and applied DC4 to the inside (Dow Corning 4)  which is sort of like silicone sealer that never hardens and it's water proof. Reinstalled the adjusters.
I set all 4 of them to position 3.
I checked the toe in and camber before-hand with the vehicle sitting on the ground and again after using a jack to raise it up 2".
I noticed the toe in angle changed by about 3/16" additional. As truck was jacked up to 2" higher, the steering rod angles changed. This pulled the front of the wheels inward.
In my opinion, the CV angles didn't change that much, it didn't look like it would cause any accelerated wear. The upper ball joint does not appear to be at a severe angle. Perhaps if i drove this off road a bunch it would make a difference but for street operations I think it's fine.
Since I was doing this install by myself I had to disconnect the sway bar links at the lower control arms to get the new struts to go in. If there were 2 people involved I think I could have gotten them in by prying down on the upper arms with a lever against the springs. It only took a couple of minutes to unbolt the sway bar links.
There was no need to disconnect the upper ball joint or the tie rod ends. I went after the 3 strut tower nuts from the engine compartment, that allowed an air ratchet (with extensions) on the 18 mm nuts. The new nuts supplied with the struts are actually 15 mm, the same as the lower bolts.
I lowered the vehicle on to plastic trash bags that were folded in half and had grease sandwiched between the folds to make the alignment check easier.
The initial adjustment to the tie rod(s) was to lengthen them one full turn. That seemed to reset the toe to the original front to back measurements of the tire . I measured the distance at a tire groove on each.
I measured the camber angle with my phone's leveling app and it showed it was still at zero as it was in the beginning.
I didn't worry about the caster.
The steering wheel angle was off to the right a few degrees but the vehicle drove straight at 75 mph. I tweaked the tie rod end lengths 1/8 turn at a time equally until the steering angle was perfect. I think the toe angle is really close but I will take it to an alignment shop this week.
I haven't done a headlight re-aim yet but I lowered them both by one turn on the adjuster, for now.
I like how the truck looks now that it sits 2" higher in the front.
Truck-1.thumb.jpg.8bdc76d90bde2a096137e352219fdc2b.jpgTruck-2.thumb.jpg.cd3d590c4f71b969ce74e9795b5f4632.jpg
You should consider this to be a regular maintenance item.  Rancho has had problems with their adjusters freezing since the day they first released adjustable shocks, which has to be at least 15 years ago.  They still haven't figured out a solution apparently.
Sharp looking truck by the way, love the blue
debating replacing shocks with some sort of bilsteins while I’m in there putting the 2.5” level on, any input on that?
    RSTRICK
    RSTRICK
  • Who's Online   3 Members, 1 Anonymous, 593 Guests (See full list)
    • Coming back from towing a car to my daughter in Nashville truck started making a screaming noise from underneath.  Pulled over placed in park and sure enough whining noise from underneath.  Dropped at the dealer fearing new tranny or another front pump/cover replacement.  Service writer said it sounded like the tranny too...  Well $300, new idler and a belt all is good.  Pop the hood and give a listen. lol  Now I'm telling dealers I'm no longer interested in a new truck.
    • HD uses the 6.6 gas.   Oil consumption while heavy working is considered normal.  1 quart per 100 gallons of fuel is the normal rate above 8600lbs GVWR.  If more than that, it is considered excessive.   They will have to perform an oil consumption test using the guidelines in TSB 03-06-01-023J.     Information on Engine Oil Consumption Guidelines All engines require oil to lubricate and protect the load bearing and internal moving parts from wear including cylinder walls, pistons, and piston rings. When a piston moves down its cylinder, a thin film of oil is left on the cylinder wall. During the combustion process, part of this oil layer is consumed. As a result, varying rates of oil consumption are accepted as normal in all engines. Oil Consumption Oil usage has a direct relationship with the amount of fuel used. The harder an engine works, the more fuel and oil it will use. Therefore, oil usage as a factor of fuel usage is a more accurate indicator of acceptable oil consumption levels than vehicle mileage for vehicles at or above 8600 GVW. The accepted rate of oil consumption for gasoline engines in vehicles at or above 8600 GVW is 1 liter (1 qt) within 400 liters (100 gallons) of fuel used. This rate only applies to vehicles under warranty, maintained in accordance with the appropriate maintenance schedule, driven at legal speeds and within design intent of the vehicle. Many factors can affect an owner's concern with oil consumption. Driving habits and vehicle maintenance vary from owner to owner. Thoroughly evaluate each case before deciding whether the vehicle in question has abnormal engine oil consumption. Gasket and External Leaks Inspect the oil pans, engine covers, and the engine oil cooler for leakage. Inspect for oil leakage into the engine coolant. Improper Reading of the Oil Level Indicator (Dipstick) The vehicle must be parked on a level surface to obtain accurate oil level readings. Verify that the dipstick tube is fully seated in the block. When checking the oil level, make sure the dipstick is wiped clean before taking an oil level reading and fully depress the dipstick until the shoulder bottoms out on the dipstick tube. The dipstick should be the proper part number for the engine/vehicle that is being checked. Not Waiting Long Enough After Running Engine to Check Oil Level The vehicle should be allowed to sit for at least 15 minutes, after the engine has been shut off, before taking an oil level reading to assure the oil has had enough time to drain back into the crankcase. In order to ensure accurate results, the temperature of the oil should be close to the same temperature as the last time the oil level was checked. Improper Oil Fill After an Oil Change Following an oil change, verify that the proper amount and type of oil was put in the engine and that the oil level on the dipstick is not above the full mark or below the add marks. Refer to the Owner's Manual or Service Manual for information on recommended oil quantity, viscosity, and quality. High Speed or High RPM Driving Continuous driving at high speeds/high RPMs may increase oil consumption. Because this may not always be an everyday occurrence, it is hard to determine exactly how much the oil economy will be affected. Towing or Heavy Usage Towing a trailer or hauling additional weight will increase oil consumption. Large frontal area trailers will further increase the work required from the engine, especially at highway speeds, and thus increases the rate of oil consumption. PTO Operation Operation of a PTO will increase fuel and oil usage, as the PTO driven accessory uses engine power to operate. Crankcase Ventilation System Verify that the positive crankcase ventilation (PCV) system is operating properly. Blockages, restrictions, or damage to the PCV system can result in increased oil use. Oil Dilution from Condensation On vehicles that are usually driven short distances, less than 8 km (5 mi), especially in colder weather, condensation generated from cold engine operation may not get hot enough to evaporate out of the oil. When this occurs, the dipstick may indicate that the oil level is over-full. Subsequent driving on a trip of sufficient length to enable normal engine operating temperature for 30 minutes or more, in order to vaporize excess moisture, may give the customer the impression of excessive oil consumption. Engine Temperature If an engine is run at overheated temperatures (see Owner's Manual or Service Manual) for more than brief periods, oil will oxidize at a faster than normal rate. In addition, gaskets may distort, piston rings may stick, and excessive wear may result. Verify that all cooling system components are in proper working order. Engine Wear Piston scuffing, excessive piston-to-wall clearance, tapered or out of round cylinders, worn, damaged or improperly installed valve guides, seals and piston rings will all cause an increase in oil consumption. Measurement of Oil Consumption Engines require a period of time to BREAK IN so that moving parts are properly seated. Therefore, oil economy should not be tested until the vehicle has accumulated at least 6400 km (4000 mi). An exception would be allowed only if an engine is reported to be using more than 0.946 liter (1 qt) in 1600 km (1000 mi).   Verify that the engine has no external leaks. Repair as necessary. Verify that the engine is at normal operating temperature (see Owner's Manual or Service Manual). Park the vehicle on a level surface. Wait at least 15 minutes, after the engine is shut off, before checking the oil level to make sure that most of the oil has had time to drain back into the crankcase. Check the oil level and record the vehicle mileage, date, and exact oil level on the form included in this bulletin. Next ensure the oil level is at, but not above, the full mark on the dipstick. add oil if necessary. Also ensure the proper viscosity and quality oil are being used as recommended in the Owner Manual Ask the customer once they have consumed 100 gallons of fuel schedule an appointment and return to the dealer for inspection. If the final evaluation shows that the engine uses more than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, follow the published symptom diagnostics as described in the appropriate Service Manual. If the oil consumption test shows that the engine uses less than 0.946 liter (1 qt) in 379 liters (100 gallons) of fuel used, explain to the customer that their engine meets the guidelines for oil consumption.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
