Questions about my new 2014
I don't have the rings around he radio knobs and never noticed. If they come out with a fix, I may entertain the idea if it's sensible.
Sent from my DROID RAZR HD using Tapatalk
  • Replies 407
Since Chevy does not want to fix this and my dealer is clueless I am just going to buy the resisters and solder them in myself. Paid 49K for the truck and so far I love it but these knobs kinda bug me. Wish GM would be more receptive to problems and be faster at fixing them.. I feel bad for the people who dont know know how to solder and are unable to fix it on their own..
Fixed it!!! R34&R45 with a 1/8 watt resistor 2.2k. attachicon.gifimage.jpg
Can you show any pics of the installed resisters?
Honestly I am going to take it to a professional place so they can solder it better than I did. The sockets are way too small and I don't feel confident with what I did even tho it does light up. Wait till this weekend and I'll will post pics of what he will do for me.
Agac, can you do a write up of this for those of us who got hosed by GM
For the A.C. Central control knob:
Take apart your center dash and disconnect the three conections that are attached.
Remove the AC control unit from the trim. ( pull the clips back and pull unit away from trim as you do so.
Remove the grey plastic behind the unit ( same way)
Find sockets R34 & R45 towards the center of the circuit board.
Solder a 1/8 watt 2.2kohm resistor to each socket. Make sure you do not allow it to touch anything else and also make sure it will be ok when you cover the circuit board. Space is very limited. Once you have done this, everything will be fine.
Because your not searching for anything else, you do not have to take apart the entire unit like I did. Good luck.
I have a crew cab, std bed, LTZ ordered and is scheduled for production next week. Based on what I have read here and what Jennifer responded earlier, these lights are supposed to, and should work. Guess I will look before I accept delivery!! Is there anything else I should look for that guys have found problems with after delivery. I am assuming delivery will be around mid January. I have owned Chevys all my life, but this is my ultimate truck. Seems pretty chickens**t to sell a $50,000 truck and let this fall thru quality control. Chevy needs to fix this for all you guys that bought early versions. It is things like this that will keep GM from EVER dethroning Ford!!!
I love that after we here made GM aware of their mistake, they go ahead and make the correction on the production line. Unfortunately we the ones who located the issue get f'ed over from GM. Classy GM!
Sent from my XT1053 using Tapatalk
Right on. I feel the exact same way!
I would understand if they said only the High Country models have the working knob lights, but to say some 2014's will having working knob lights and the customers who purchased early wont is ridiculous. Apparently GM's Customer Service is at a loss for words.
Hello everyone,
I'm sorry to share that some of the information shared in my previous statement was not fully accurate. We have been working with our brand quality managers to make sure we have most accurate information to share with you all regarding this question. I wanted to update you all that I am continuing to work with the team and should know more information by the end of the week. As soon as I have any new information, I will let everyone know on the forum.
Sincerely,
Jennifer T.
GM Customer Care
I'm willing to give her sometime to get us a better answer.........
I am also willing to give customer service time to come up with an answer. If they stand behind their product and make amends with current owners then I will be satisfied. Otherwise I have no other complaints and the truck really is awesome I am liking it more everyday except for the lights and a few quirks with the radio.
What's the alternative to that? They DON'T correct the problem, and NOBODY gets working LED's??
However, they REALLY SHOULD get these working in EVERY truck (at least, in every one in which the owner has noticed and requests them to fix the problem). So what, they have to cough up a couple thousand resistors and/or swap the whole circuit board - who really cares HOW they fix it?! - especially when it's ultimately a "quick fix". I don't agree with the attitude of "we're sorry your truck was built too early - we can't make it work like it's supposed to; like the newer ones".
Mine showed up with the LED's. The sales guy said that they had heard from quite a few people about the issue.
    Greg3160
    Greg3160
  • Who's Online   3 Members, 0 Anonymous, 372 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
