On ‎7‎/‎26‎/‎2019 at 5:49 AM, no12nv said:
what size rim/tire combo you running bro? lift? i wud love ta get my ride close to your look.
Sorry for the delayed response, haven't been on here much.  I'm running 20x10 -12s with 35x12.50 Toyo Mt and 6 inch lift.  I do get a slight scrub in the front when hard turning to the right, but other than that its perfect!
On 8/9/2019 at 8:23 PM, no12nv said:
i need a lift guys .. not sure on what to do. i want to run fuel d509 deep lip 20x12 on toyo at2 extremes or nitto ridge grapplers. i hope to run 33.5 or 34 x 12.5s my front sits exactly 2.5in lower than rear. i can change rim size to a 20x9 with less offset n less lip. what do ya'll think would be best lift for what i want without going crazy? i was thinking 3.5 front n 1 rear? would that work? thanks
update.. ordered the bds 4" lift kit package 712h i believe moto metal mo970 20x10 -24 offset gloss black and ridge grappler 33x12.5s . install next tues. anyone think i'll have any rub issues? thanks for the input
Edited by no12nv
After 112k miles the leather wrapped steering wheel and shifter handle in my 14 Sierra 1500 Denali were showing the wear and tear of the miles. So after a visit to EBay, $150 and 30 minutes later I have replaced them both with factory new OEM replacements. Came out great and was an easy way to take the miles back off my interior.
Looks great!
How "much work is involved" in changing the shift handle?
Something I have been thinking about doing.
19 minutes ago, JimCost2014 said:
Looks great!
Super easy. Maybe 10 minutes total. Shift handle is one Torx screw and a small plug. Pull off the top and bottom plastic steering column shroud, unplug the wire from underneath and take the single screw out of the base of the shifter lever.
Edited by Vulcan762
How much was that leather shifter? by any chance u have the part number for the black leather shifter? Looks badass man I just added a heated steering wheel on mine and the leather dash, Denali cluster should be here on Wednesday Chevy blue with unlocked hmi and radio module
On 6/19/2019 at 12:50 AM, JimCost2014 said:
Welcome to the site.
Beautiful truck!!!!!
Looks great! Tell me a bout the lowering kit. How far did you drop it and whos parts did you use?
Thanks for the reply, think I will go ahead and order one, and give it a shot.
Really like the way it looks in the wives Tahoe.
Another easy mod is to switch the center console lid (if you have the floor version) handle to the chrome version.
I did this one, think it looks pretty sharp.
How about the steering wheel? What is the process for replacement?
this is the video that I used to help me swap my steering wheel has everything u need to know. Oh yeah thanks  @TinkeringFox for your video @pgamboa shared the link with me awhile back appreciate y’all for all y’all helpful videos
On 8/17/2019 at 5:56 PM, Vulcan762 said:
What lowering kit did you use?
Beltech 4/6 drop originally. However I wanted to run 285/60R18 tires, so I raised the front end an inch, so it's more of a 3/6 drop right now.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
