I believe this whole 10 min run limit thing is about liability. I think it's a concern about carbon monoxide poisoning, etc.. Even Chris is pretty conservative about doing much with this.
Your starter isn't going to fail prematurely. You never hear about starters failing anymore. As far as I know it never would run 20 minutes unless you timed it just so- it always added 10 minutes from where you did the command. My 2011 manual says as much too.
Anyone had an issue when using remote start where seats do not heat up/cool. The settings for both are set to "on" but neither works with remote start in my '15 Sierra Denali.
I have only had my vehicle since September, so here (in Edmonton, AB, Canada) I haven't really had a chance to test the auto cooled seats. I can say for sure that my heated seats come on with the remote start, although the lights for the heated seats do not. You can only tell from the temperature of the seat itself.
Everything I've read says that when those settings are on, the truck cools the seats on "hot days" and warms them on "cold days", but I can't seem to find what temperature defines "warm" and "cold".
Mike-I'll check closer. The indicator lights not coming on as they have in the past several trucks I've owned concerned me. With only a 10 minute window, they don't have time to warm up a lot but I'll check closer.
I've noticed the same thing and we have the same vehicle. Would love to know what defines warm/cold. The heat comes right now, but I'm thinking that the seats are not coming on as well.
I have noticed my seats heat up on remote start, they aren't as hot as they would be after having them on high and driving around for a bit; but noticeably warm compared to the other surfaces in the truck in the morning. Once I turn the key I still have to turn the heated seats on. I think that's how they are supposed to work though, correct me if I'm wrong.
-Skeet
It's only 39 here currently. I double checked and the HVAC heat comes on, but the heated seats definitely are not warming up even though I have the setting turned on.
Do they work when you turn them on after a key start?
Yep, everything functions normally once I put the key in and start driving.
Different model, but I think this applies.
http://sandyblogs.com/techlink/?p=3033
"The system uses the information obtained from the Outside Ambient Temperature sensor on the vehicle. When it reads 80°F (27°C) or higher, it will allow the operation of the ventilated seats during a remote start. When it reads 50°F (10°C) or lower, the system will allow operation of the heated seat during a remote start. If the sensor reads anything in between these temperatures, neither the heated nor ventilated seats will turn on regardless if they are enabled in the personalization menu."
Thanks! Admittedly, I have never looked too hard, but that's the first time I've seen numbers around when they cool or heat. Like you said, different model, but could be accurate.
  • 6 years later...
Canadian igloo is a complete moron. I don’t think you actually live in Canada. At minus 35 C it’s bloody cold and 29 mins is not enough. “Get in and drive” guy, you really are an idiot. Nothing wrecks an engine faster than not warming it up. God, some people on here should just shut up.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
