What are you lowered guys using to fix and adjust your camber in the front? I am dropped 2" in the front and the alignment shop maxed out my adjustment bolts for the camber so I still have negative camber. Was just wondering what aftermarket stuff you are using for adjustment. Any help would be appreciated.
Edited by smokenu
So I am going to buy a 2015 1500 Silverado LT and wanted to level the truck via rear shackles just because it will make it look better; but I have been reading about a few issues on this topic such as the bump stops bottoming out, the truck making some funny noises when going in reverse due to some sort of banging caused by the shackle drop, and also having to install shims due to the changing of an angle of some mechanical part( I know nothing about trucks or auto mechanics in general); I just wanted some advice from the guys who have done this type of drop on 2014+ trucks and wanted to know if yall could shed some light on these issues stated above or on any issues yall have had encountered along the way. My main concern is that I don't want to ruin a brand new truck.
Got more pics of your trucks? Looks pretty sweet and what size rims? As for alignment, I'm lowered 2" up front with spindles. The shop I took it to for alignment didn't need to do anything special and got it near perfect. What did you do to get the 2" drop, springs?
This thread is full of answers to your question. Some don't have any issues, some need driveshafts cut,I needed shim and a carrier bearing kit. Each truck is different and no one can answer your question on what you will need after a shackle install, prior to any work being done. Sounds like your best bet will be to let a shop do all the work for you.
Belltech has a kit.
My truck aligned perfect, no pinion shims, and no drive shaft cutting either.
RT
Hopefully mine goes the same way. Finally got around to it, the shackles are ordered and she goes in next Monday.
Figured I'd jump in here. I stressed about the alignment when doing my drop and researched all over the place trying to find the answers. Everyone seemed to have a different experience or opinion on what I needed to do to keep the alignment in spec. I also found so many positive and negative reviews on some of the same products it made my choice even harder. Eventually I went with a full BellTech kit that included front lowering struts and a rear flip kit with hangers (the 5/6" kit. I also installed the camber correction kit that BellTech sells (the one bigsapper is talking about above). I consisted of alignment cams and slotting the upper control arm mounts for addition positive camber. Eventually I installed the front struts at their 2" setting and the rear kit at the 5" setting. On my 2014 single cab this still gave me a slight rake of about 3/4". Without the BellTech cams the truck would not have came back into alignment. I have also had no vibration that some have experienced and no issues with the drive shaft length (bigsapper mentioned on another forum he had some trouble with his BellTech kit) Here's how it turned out.
Before
After
Alignment cams
Nice!
Let expound on the Belltech kit. It's a good kit you just need a good installer. The vibration was from loose bolts. :S
The only quibble I have with the kit is concerning the driveshaft. The instructions specifically state not to remove the driveshaft. I contacted their support but we ended up agreeing to disagree. I get their point that the driveshaft doesn't need to be cut to install their kit, but if you need to remove the driveshaft for any other reason you're going to be in a jam (literally). Getting mine cut and rebuilt wasn't a big deal to me since I track my truck and I had road mapped an upgraded driveshaft anyway.
Might be good to post the pic. Lol
What did you use for the lowering, and did the vibration occur after you lowered it?
Edited by TKLP
Alright, so I finally got around to dropping the back of my truck. Used the Belltech shackles, my cousin did it for me at his shop.
Before:
After:
Before:
After:
As it sits now, the left side is 1.5" higher than the front, and the right is 2" higher (started out as a 4" difference!). In the future I may decide to take the blocks out so it's nearly level, but for now it's a big improvement. I'll drive it for a while and see. As is I haven't noticed any adverse effects on ride quality.
2" Shackles only did not remove blocks
Fender Measurements???
I'm getting 36" front and 37 1/2 rear. But I'm thinking of putting it back to stock. I'm getting vibration and noises from the back after the skackles was install. Looks good but not worth it.
I am thinking of doing the shackles and block to lower the back. Can I put the Air Bag Helper Springs on with this. Can I use the same ones for stock? Or do they make different ones for this?
    250.3k
    BryantM4
    BryantM4
  • Who's Online   6 Members, 1 Anonymous, 1,130 Guests (See full list)
