I'm looking to get the same kit from Belltech 6401 and from what I've read you'll need to:
  • Remove the tow hitch.
  • Bend the pinch weld on the bed to get the top shackle bolt out Or raise the bed.
  • If you want 3" you'll need to remove the 1" spacer between the leaf spring and axle.
  • If you only want 2" no need to remove spacer.
  • If removing the spacer be sure to line up the reference pin on the axle back into the leaf spring pack.
  • If you want to make things a little easier, removing the spare is optional.
Be sure the jack stands and jack are position correctly for optimum safety.
It would be stupid to remove the hitch but leave the spare tire in place
What is a hitch and a spare tire?
  • Haha 1
Hey everyone, new to the forum and new to this body style. Just recently upgraded to 2015 Sierra from a 2006. I love the truck but I am ready to be low again. I have read over almost this entire thread and still have questions. I want to go 4/6-4/7. Does that require a 2 pc driveshaft and notch? I believe I am going to go with the Mcgaughys 3/5-4/6-4/7 kit so I can have options. Any personal pros and cons with Mcgaughys?
Edited by SlowCole
Best for crewcab is 4/6.  Mcg is my favorite and i run it on my regular cab    you should be ok without yhr 2 peice but id look into it for future.  Reklez makes that conversion for a pretty good price
Awesome! I wanted to go 4/6 but I read a lot about needing a 2 pc driveshaft and notch. If they aren't required, but recommeneded, then I can go ahead and pull the trigger on the kit and work on the notch and 2 pc after that.
A notch would be nice but not needed.   Also dont use thr mcg bump stops. Get the belltech yellow sponge ones
Well got the belltech “2/4” drop on my 2018 reg cab z71. Followed directions on lowering the front which was the struts with spacers and new springs. Used only the bigger single spacer per directions and let’s just say it’s not a 2” inch drop ?‍♂️ more like 3-4”. I cant even pull over a parking spot curb without hitting front valance. Did the rear the same time as well. So I wasn’t aware of how low the front was yet. So flipped the axle on top of the spring. Knocked factory rear hangers off put belltechs hangers on in bottom 4 holes with their shackle which should be a 4” drop. Which I think really was a 4” drop it’s just the front was so low it made the rake look ridiculous. So put factory shackles on it to give it a 5” drop which helped out with the stupid rake. Also I had to cut tailpipe off because leaf springs would be right in the way of its factory exit location. Any else have to do that to the exhaust?
Factory ride height
“2”/4”” drop
Factory ride height
“2”/4”” drop
Explain what you did in front please. And give me a .measurement fron center of hub to bottom of fender lip
18” from center of hub to lip of fender on front and 20.5” on rear.
So the kit that got sent to me was the 987SP
Which contained individual parts kits. P# 25004 Which is the lift/lowering struts, also in the big box was a pair of belltech coil springs. So I put together the new struts with the single 10mm spacer ring “see picture below on instructions for 2inch drop so you don’t have to search for it” and the new coil spring provided with factory spring isolator assembly up top. I wish they had one big instruction manual for the 987sp kit.
All you have is 1 ring in each strut? And youre using thr spring as well?
Just now, Breedsrt said:
That is correct
Ya you messed up.  1 big ring only is 2" of drop. And the spring ot came with is another 2"
Sheet!!! I guess I shoulda looked at it more. Probably would have seen the springs were shorter than factory one. I was kinda in a hurry. How would you go about bringing it back up? Just add 4 rings on top of the single ring on them now that would make it a “factory ride height” and use the belltech coil? Or take that coil off and put factory on?
How i would do it is put 2 rings in front bringing it up to 3" drop.  And then drop the ass end 1 more inch making it a 3/5 drop but thats just me
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
