First post, after a lot of searching...
Planning on picking up a RCSB Silverado, 2016, Z71.
Need to tow up to about 6klbs. Not opposed to helper air bags, but want truck dead level unloaded, with enough drop to be recognized, but still enough room for 22x10, -24ish offset, preferably a 12.50 mud terrain. Doesn’t have to be 12.50, but I want wide without stretch.. and with a strong shoulder of a mud terrain.
I think it’s on the outskirts of possible, with a little trimming, and think a 2/4 or 2/5 would be best option.
Problem is that I see some kits at 2/4 level, and some kits with 5” rear drop still with a ton of rake. I know there are tolerances and all, but on average-what rear drop gives dead level rear on a 2” front drop?
Or do you think this is unreasonable, and I should just drop the rear level and run 33x12.50s on 22x10 with stock front end?
This was my 2015 on a 2/4 drop with 22x10 wheels. I think the tires were 305/45/22 which is pretty close to 33x12.0 and I was already rubbing the fender liner.
With an even wider mud tire youd definitely have rubbing issues. I would do a simple reverse level, and call it good. 7b72bbddb68c25be5c0f20b88461ed5d.jpg
2" drop shackle and pull the leaf block and leave the front, it'll be dead level unloaded. I would be willing to bet that 22x10 with that offset and an aggressive tire will be close to rubbing stock so I can't imagine it'll work with a 2" drop up front.
2” shackles with block removed. And a set of homemade custom bracket for airlift bags. It’ll sit level with out without load!
  • Like 4
On 1/27/2020 at 2:10 PM, KEEPS808 said:
Yea when you order from atomic he asks you to measure the distance between the center of your rim to the bottom of your fender and he determines what parts he’ll send. That’s why I went with him instead of twisted.
Well, after much deliberation and mathematical equations using the formulas at the Viking website and Ridetech's coilover formulas I found out that our truck geometry calls for a 12" spring with 800 lbs/in for a 1" drop by spring... so, no wonder I am still bottoming out even running the coilovers at 17/15... I ordered some AFCO springs at 850 lb/in, and if the Vikings can't handle them I will buy Ridetech's coilovers and use the Vikings on the rear once I do the 4 link suspension.
As a side note, I did ran the 10" math, and they suggest a 1000 lb/in, but this is with the OEM LCA. I had no idea the LCA had so much influence on the spring rate of a car.
Damn man you went all in on that research and calculation stuff lol. Awesome. Tbh I’m not all that knowledgeable on all that. I just trusted them at atomic and hoped for the best and it turned out great. You sound like you’re on the right track for a smooth ride though! Are ridetechs better? I never read any posts with them in it.
To have the truck level, you need a 3" difference between front and rear. Almost every 2/4, 3/5, 4/6 drop that I have seen will result in a little rake. Here is a pic on my truck, it's a Crew Cab, and I have a 3/5. That's with a full tank of gas and some tools on the bed. Bed empty and it is more noticeable.
They are certainly better as far as that they actually asked you for measurements. I think Ridetech uses Fox's coilovers, as their main thing is Air Suspension. Their HQ's are around $250 each, no spring, but are single adjustable. Their 3 way run at $850 I think each. I have a very nice ride now, better than most cars on the road for sure. But after all the investment in suspension that I have done, plus the 4 link in the rear, that will not cut it. The fact that I am traveling down almost 3-4" hitting on the top of the inner fender metal on a coilover that is supposed to have 5.25" of full travel is not good. I bet once the 850lb/in go in I will see the 2-3" on compression I am suppose to have. That will stop me from bottoming out, at least on the highway.
Ridetechs are very popular on the muscle car scene, mini trucks from the 80's-2000, and HotRods. They have a few systems for fullsize trucks, but nothing for ours at this time. But since I already have the mounts for the Vikings, I can use those to mount their universal fit shocks, or I can reverse engineer them if I need to make them a little wider.
Edited by Maiden69
Yup I agree with the 3" difference front to rear in order to achieve a more level look. I am currently sitting at 2/4 with my truck and will be adjusting to 2/5 this spring for a more level look.
On 10/8/2015 at 8:57 PM, 07Softail said:
This is a 3-5 also
Nice truck..Should i run a cnotch with a 3/5 drop?
my truck 2016 reg cab silverado 2wd
I'm at 4/6 on my 2016 reg cab, no notch needed.
I have a 2/5 with no notch.
On 11/10/2018 at 7:21 PM, qwank said:
My truck with a 2/3.5 drop for reference
Truck looks great !! Getting my 2/4 drop installed tomorrow on my 16' reg cab wt. Might have to change my wheel/tire setup. currently running 20x10 -24, 295/45/20. so my wheels stick outside of fenders about 1"
Edited by cmb570
Looking for some info on drop and tire sizes. I’m thinking 24” reps and maybe a 305/35 or so tire, not sure how much I want to go down and look good but not be too low. My truck is currently lifted and just looking to change it up some anyone have pics of a 3/5 and 24’s with a 305/35 tire or something close?  Pic of my truck as it sits now
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 649 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
