Got it figured out. Was using the wrong grey wire. Nice of them to put 2 grey wires on there
update ...it was the thicker brown and yellow and the thicker grey and green..had a problem with the connection inside the tailgate that was making it not work...also make sure your actuator arm isnt bent..mine was a little tweeked and wasnt fully locking the gate..thanks for all the help guys..fyi my truck is a sle crew cab so that the wires for that...
Just to note my experience, I too had to use the brown/yellow and thicker grey/green. 2015 Silverado 1500 LT.
Mine also wasn't fully locking, it wasn't pushing far enough so I've temporary added zip ties for the arm to hit.
Hello I just installed the pop and lock on my truck everything work except when you lock it with the fob the little plastic arm doesn't come back enough to lock it unlock works fine,anybody else have this happen and how did you fix it,post pcs if possible thanks
The post above yours had the same issue. They used zip ties.
got mine installed today ended using the thicker of the brown/yellow stripe and the gray/green stripe wires while testing i noticed something weird when locked with the door closed window down i was not able to unlock the doors with the button on the door i had to use the key fob this would happen after the interior lights went out and the red dash light was blinking is this some kind of anti theft cause it pretty dumb. i can lock myself in my truck and not be able to use the unlock button ill have to pull the handle twice to get out. i didnt see anything in the manual about this it just seems strange to me.
Quick question -- since this is tied into the door locks does the tailgate lock automatically like the doors when the truck is put into Drive then unlock when you put it in Park?
I have mine set to lock/unlock with the passenger doors, so mine doesn't unlock when I put it in park. It locks when put into drive.
Cool, I discovered mine wasn't locking as well. I attached one tie strap so the head was in the corner of the plastic arm. Just enough room for the lock cylinder pawl to get past it. Thanks for the tip!
I ended up in the same boat. I emailed Pop & Lock asking if there was a fix and they had me send a video of what it was doing, to which they offered exactly zero help as their "tech support" didn't have a fix, and they won't sell any replacement parts. They were more than willing to offer me a whole new unit at full price, however. Needless to say that left a bit of a bad taste in my mouth and I won't be buying anything else from them in the future. That said, the zip tie trick is working for me as well. Sorry for the rant.
  • 4 months later...
Just installed mine today.  Thanks all for the info and zip tie trick. I too broke my driver side wire cover. 25 degree weather and aggressive negotiations with it didn’t mix well.  Lol.
Some super glue and zip ties and we were back in shape
Edited by squeak93
On 1/7/2018 at 1:22 PM, silveradosid said:
I had the same problem with locking what I found was the arm on the handle was binding I loosen the screw a little and now it works fine
Which screw? I have the issue with it periodically not locking as well. About to add the zip tie method myself like others above. Its odd though, if I got back and forth unlock to lock enough, eventually it does lock.
The screw holding the white plastic locking arm.  1/4 turn is probably all it needs, however I found that the zip tie trick helped on top of this.  Mine was the same way where if I locked and unlocked enough it would finally do what it should, however it was more of a hindrance than hitting lock once and knowing it was going to actually lock.
I just installed this power locking tailgate. Is it supposed to work with the drivers door or the passenger doors. I tried 2 different wires and they both only work with one click of the key fob. I wanted to have it open with the second click on the key fob.
I've been thinking about adding this to my 15.  But if the newer model have a factory actuator, can it be added and wired the same as the pop and lock?  This seems it might be a bit more reliable and more positive operation.  Just a thought.  Any one tried it?
    RichardRS
    RichardRS
  • Who's Online   3 Members, 0 Anonymous, 828 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
