Yes, but yours isn't textured, is it?
Mine is textured and I love it. To make sure it's the right fit call nfab they have the best customer service I have ever experienced. The seller forgot 2 screws in my order and I called nfab and they sent next day air for those screws at no cost but saying thank you for being a nfab customer
2014 Silverado 1500 LT V8 4x4 All-Star Edition
I did use the rubber, but your not "suppose" to have too on the 1500 Crew Cabs according to the directions. I figured mine hit due to the body lift, since it had to be adjusted for it, which puts it in a different location then the stock adjustment. Easy fix... I was just surprised he had an issue with a stock truck and apparently you did too?
I actually have a 1.5" Body Lift installed
The drivers side rear bracket lines up directly with the parking brake assembly. When the steps are up, the bracket does hit the brake assembly. I don't recall reading that I didn't need it due to me having a crew cab.
The directions state the rubber is only required for the 2500 HD trucks
Haven't had any time to mess with mine more but next chance I get if one more call to an AMP tech doesn't fix it I'll be figuring out what I have to do to return them
Edited by baggedlvintegra
They all basically look the same... just do some image searching on google. If I still have my directions I'll scan them and post them up but I think I threw them away(they weren't even for the right truck but they got me started).
Looks like the mount up to the same locations as the AMP steps from the previous picture posted.
Its a very simple design, I'm sure you could makes some and even make them look better/more functional140.124.800x600.2_STEP_NERF-STEP.jpg
http://www.ranger-forums.com/attachments/interior-exterior-electrical-misc-119/58842d1366152306-n-fab-nerf-step-bars-corvallis-nfab2-jpg
Thank you
I just received a call from my AMP dealer. They are finished with the installation of the power steps on my truck. I'll pick it up after work.
The AMP power steps look great and my wife should be happy. Also, both out elderly mothers had difficulty getting in my truck without steps. These are low enough for a first step for them.
Wife came home and I showed her the steps. She thinks they're the coolest thing about the truck.
Edited by spurshot
"spurshot"
Can you post up pictures? Some folks have complained with the gaps not being equal from front to rear where the steps meet the body.
Sent from my iPad using Tapatalk HD
If you look at the boards along their length you can see a slight bow to them. Mine are are very near to being even but do have some bow.
Anyone know a good Amp Powerstep installer in the Austin, TX area? I've searched the Amp web site and local truck accessorry shops. There are a few that install the Bestop powerboards but not the Amp models.
I noticed a lot of discussion about the AMP powersteps, but only a couple Bestop powerboards. AMP has the longer warranty and P&P; Bestop has wireless. It also looks like AMP attaches with two bolts per arm and Bestop uses only one? True? It would seem to me that the AMP would be the way to go if I can find an installer.
Edited by chuckl1218
Cool man I appreciate any feedback he might be able to give...I'm highly experienced and have done several sets of AMPs, but I'm about ready to rip these off, literally, and mail them back in pieces to AMP...
I am looking into getting these for my truck and found this troubleshooting video that addresses binding and large gap at the one end. Maybe this will help...
http://www.electricstep.com/AMP-Research/pc/Technical-Support-c31.htm
Austin area - B&H Customs, Star Customs or Pickup Heaven - all three should have the ability to sell and install.
Edited by muttman14
tried the tip from cansled, didn't work, called AMP and talked to a tech for 30 minutes, didn't work...beyond frustrated with spending $1000+ on steps that look like garbage, just feel defeated
And the driver side constantly rubs the parking brake line bracket
You have a 1.5" body lift right? That is what is most likely causing your issue. I have AMPs on my 06 crew cab, and everything was fine until I added a 1.5" Body lift. The same thing was happening on my truck, and I ended up relocating the motor, bracket, and arm further back to clear the parking brake cables. It still hits, but it made it better and the step retracts all the way like it did before the body lift.
I'd also check to see if they are hitting the body mounts on the frame when retracted. I had that issue on the passenger side. Some adjustments and a little help with the grinder on the mount fixed that issue.
It's the price we pay when you start stacking mods on top of mods. Clearances that are tight already get changed and then more work is required to get them to play nice together.
Edited by tsdrumm
thanks for posting those other places muttman, didnt even know those were in the area. Chuck, you may also try Infinity Conversions in Pflugerville. I'm not sure if they do that or not but that is where i had my bedliner put in and bumper pieces put on. They also said they would vinyl wrap the chevy emblems for like $25 ? i think. need to go back and do that.
Thanks Wood and muttman! I worked with Pickup Heaven before so they were the first I looked at, but their web page is down. Infinity and B&H both list Amp retractable steps, so I'll reach out to them. I also sent email to AMP to let them know they don't list anyone in Austin, but Bestop does. I asked them for help locating an installer. It'll be interesting to see what they say.
I'll report back as this unfolds. Thanks again!
Just plastic dip them for 5 buck plus blue scotch tape
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
