Loaded up the kayaks and went to the lake
Sent from my iPhone 6+
I think I got the upgrade with the error cancellor built in because I paid $200 for everything, and I guess mine are 35w not 55w, guess I was mistaken, but regardless, I like them a lot. I just went to the store frustrated and asked what he recommended and left with the HID kit. Guess I didn't really ask a bunch of questions. But you could always call him if you have questions.
Thanks man. Do you need to buy 2 kits, one for low and one for high?
Yeah, but I probably wouldnt use them for high beams. I'm gonna go with LEDs for my highs.
Edited by Roidz
I think the picture is fake, just a photoshopped image, boat added and background changed from the picture of your signature. BUSTED!!
If you ever need to use your high beams to flash you won't be able to use them much if you use HIDs. I'd say put in LEDs in the high beams so you can easily flash still
Haha they are about the same angle. That's funny. But hey, the tailgate is down in this one [emoji6]
Got my Rigid brackets in today and got them installed. It was actually fairly easy to cut everything and get them installed.
Why was it towed?
Sent from my SAMSUNG-SGH-I997R using Tapatalk 2
Was at a stop light and it started shaking violently, then it shut off. Won't turn on anymore. Not sure, maybe the fuel pump went out?
i have my truck since middle of March
i did weathertech floor mat, center console (all fonctionnal), upfitter switch, cover seat, under seats light, driver assist handle, new wheels mag,
new tires and bigger a little, 2" levelling front, round oem step bar, plastidip front and rear bowties, removed all others chromes parts,
installed a tonneau cover soft trifold, oem rear fenders liners and a bed liner.
TODAY :) i have wash again and wax the beast, installed a tail gate shock, a trailer brake controller and a small check up ( 4000 km )
i want oem towing power mirrors with rear view led, heating, powerfold and black no chrome........soon soon :)
