Tweaked on my Volumetric Efficiency and MAF Calibration a little more.. :ughdance:
Finally had time to build the Relay panel for accessory lighting. Built and extra for a friend.
Spare:
Installed:
Added Rancho Quicklift struts/coils and RS9000 shocks. Just as expected, added right at 2" to the fronts. Ride at 4 front and 6 rear is firm but smooth. Very similar to factory.
Before
After
I loaded my truck yesterday at the Home Improvement store with a skid of River rock, and 15 bags of soil. It squatted down, but not much. 53b85ef994b933a2bdebdda4140b7404.jpg
Beautiful High Country! Wish mine was a 2500HD
Thank you!
Got the bed Line X'd today. Got the UV resistant Line X Premium from Line X of Arlington, TX. $575 OTD
i need to do this...i actually work not to far from them...and i called and got a quote.
but put it on hold due to $$$ i just spent on tires/lift.
glad to know they do excellent work!!
Has anyone plasti dipped the Silverado logos on a black or a tungsten metallic? I really want to see how it turned out before I do it
Only pic of mine i can come across right now, gives you an idea though. Im glad i did it
Haven't had it done yet, but made an appointment at a local shop on Thursday to have my windows tinted. I'm just having the front doors match the rears and having them add a windshield brow.
Edited by SouthernSilveradoGuy85
Swapped out my chrome mirror caps for Summit White ones. I thought the chrome caps were overkill. Planning on leaving the chrome trim and handles though.
I really need to order my Amp steps. I hate the factory ones. I think removing them will also make the truck look much better.
Edited by Kerrslight
Could you post any more photos of the billet grille? I am considering the same one for my truck and all I can really find are stock photos.
TruckGrillB4A
In the last 2 weeks:
3" nerf bars
Line-X bedliner
Flowmaster 40 series exhaust
Kobalt toolbox
AVS window visors
Weathertech floor liners
2" Motofab leveling kit
KMC XD-Badlands wheels with 275/60R20 Nitto Terra Grappler G2's
Window tint coming next Monday and then I'm done!
2015 Sierra SLE Crew Cab Z71
and then I'm done!
You'll probably say that a dozen times. "done" is a fluidic word lol
