The leather is loose in the back of the seat and the passenger seat lines are parallel with one another. Maybe they just didn't assemble yours properly in the first place lol
Wouldn't put it past them lol...
I just sent a list of 4 things to my service advisor.
Has better throttle response for sure, and engine seems to idle a lo smoother too. These DI engines really like the higher octane fuel.
I haven't decided if it will be worth paying for 93 octane vs 89 octane, but I will try it for a few weeks and decide.
Thanks, I'm tuned for 89, and debating a re-tune for 91...
Dealer is repairing it because their tech did it with another vehicle in the service area. They are also covering the cost of painting it as well as another chip that I showed them. Just need to drop it off for the week!
That's another unfortunate, but perfect example of why I recommend staying away from dealership service departments.
Most of the time, if not every time, they cause you more damage than when you dropped it off! I learned this lesson long ago when they destroyed the black paint on my truck and dented the door. STAY AWAY, they will damage your vehicle!
Not sure why one would need that but it sure does look cool and I really like how you have a z71 logo on it that matches your gauge cluster.
Aeroforce Interceptor.
I made the pod. Doesn't want to leave it empty so i fill it in with this gauge.I might supercharge it down the road. The cool thing about the gauge is. You can check and clear codes if you need it.
You can also display any parameter that you want. Lol
Really? Well that is cool. Even if it only kept the time, it still adds a good look to your truck.
That looks freaking awesome in a regular cab!!
Agreed!
Thanks! I wanted buckets/console on my last two RCSB's but it was not an option. Never thought that it would be such an easy swap.
Edited by dla
Installed center console...
Do you have the PN for the silver side inserts and door panel inserts?
    • دليل تجهيز سيارات الرحلات البرية في السعودية 2026  كيف تختار تجهيزات البر المناسبة لسيارتك؟  أصبحت الرحلات البرية والتخييم من أكثر الهوايات انتشاراً في المملكة العربية السعودية، لذلك زاد اهتمام ملاك السيارات بتركيب تجهيزات عملية تساعدهم على السفر والتنقل في الصحراء والطرق الوعرة بأمان وراحة.  لكن السؤال الأهم: ما هي تجهيزات البر الأساسية التي تحتاجها سيارتك فعلاً؟  أولاً: صاجات الحماية السفلية  تعتبر صاجات الحماية من أهم الإضافات لأي سيارة تستخدم في الرحلات البرية. فهي تحمي الأجزاء الحساسة مثل المحرك والقير والدفرنس من الصدمات والحجارة والعوائق أثناء القيادة خارج الطرق المعبدة.  عند اختيار صاجات الحماية يجب الانتباه إلى:  - سماكة المعدن. - جودة التصنيع واللحام. - سهولة الفك والتركيب. - وجود ضمان على المنتج.    ثانياً: السلة العلوية للسيارة  توفر السلة العلوية مساحة إضافية لنقل الأمتعة والخيام وصناديق التخزين والأدوات الكبيرة التي يصعب وضعها داخل السيارة.  ومن أهم مزايا السلال العلوية:  - زيادة مساحة التخزين. - تنظيم المعدات أثناء الرحلات. - إمكانية إضافة إضاءة أو ملحقات إضافية.   ثالثاً: أنظمة الكهرباء والإضاءة  يعتمد كثير من أصحاب الرحلات البرية على الإضاءة الإضافية والبطاريات المساعدة لتشغيل الأجهزة المختلفة أثناء التخييم.  ومن أشهر التجهيزات:  - كشافات LED. - منافذ شحن USB. - بطاريات إضافية. - أنظمة إدارة الطاقة.   رابعاً: الأدراج وصناديق التخزين  يساعد تنظيم المعدات داخل السيارة على الاستفادة القصوى من المساحات المتاحة وتقليل الفوضى أثناء الرحلات الطويلة.  وتشمل حلول التخزين:  - الأدراج الخلفية. - الصناديق المعدنية. - حوامل الثلاجات. - أماكن تخزين الأدوات والمعدات.   كيف تختار ورشة تجهيز سيارات موثوقة؟  قبل تنفيذ أي تجهيزات لسيارتك تأكد من:  1. الاطلاع على الأعمال السابقة. 2. التأكد من وجود ضمان واضح. 3. استخدام مواد عالية الجودة. 4. توفر خدمة ما بعد البيع. 5. خبرة الورشة في نوع سيارتك.   مستقبل تجهيز سيارات الرحلات في السعودية  يشهد قطاع تجهيز السيارات نمواً مستمراً مع زيادة الاهتمام بالسياحة الداخلية والرحلات البرية. وأصبح العملاء يبحثون عن حلول تجمع بين المتانة والوزن المناسب والتصميم العملي، مما يدفع الشركات المتخصصة إلى تطوير منتجات أكثر احترافية تناسب مختلف أنواع المركبات.   الخلاصة  اختيار تجهيزات البر المناسبة لا يعتمد على كثرة الإضافات، بل على احتياجاتك الفعلية وطبيعة استخدامك للسيارة. الاستثمار في تجهيزات عالية الجودة يرفع مستوى الأمان والراحة ويمنحك تجربة أفضل في رحلاتك البرية داخل المملكة العربية السعودية.
    • look for it's replacement procedure on charm.li or alldata.com   For my '12, the sensor is pressed into the evaporator directly, and to replace it w/o pulling the whole hvac box, you cut a hole in a specific spot to gain access to it, and then plug the hole afterwards.
    • Sounds to me that its on the high speed data line.  ECM, TCM, and many other modules talk on it.  Wiring issue (corrosion, terminal fretting, pinched or broken wire) or a failed module or failing module (ECM, TCM, aux chassis controller).
    • Don't know if all will be able to see this. Valvoline Cuts Dexos Claim from Synthetic Oils   https://www.lubesngreases.com/lubereport-americas/11_27/valvoline-cuts-dexos-claim-from-synthetic-oils/
    • Great thread. As for parts did you try.  www.car-part.com?
