http://www.amazon.com/gp/product/B000XBCURW?keywords=303%20aerospace%20protectant&qid=1444259086&ref_=sr_1_2&sr=8-2
It is a good product. It is UV resistant.
I will let you read the reviews but I have been using it for a few years and I am happy with it.
Thanks a lot brother. You're a truck enthusiasts just like me, so I'm taking your word.... Appreciate you.
Sent from my SG Note 4 on Tapatalk
I'll have to look at the front skid plate closer. But from what I can see the tow hook is fine.
Ok well if the skid plate and tow hook valence aren't damaged I'll buy those from you
iPhone 6 '14 Silverado
Ok. Bumper should be in roughly 3 weeks from now. I'll check in between then and wil DM you if everything looks good
I use aerospace 303 as well. You can get it on anazon. Works excellent to keep black plastics looking new. Great for vinyl tonno covers as well. I learned about it from a jeep forum - kept my soft top looking brand new.
Got to haul our empty 16' utility trailer around to drop off some material at a job site.
Every time someone says to use e85 when towing just show them this post.
Hand calculated 11.07 mpg on e85. Towing an empty utility trailer for 264 miles, only actually towed any weight for less than four miles. With a loaded trailer I would be hard pressed to believe I would even touch double digits. While there was undoubtedly more power available the poor range just makes it impossible to continuously run e85.
On 93/91 I would of gotten ~17.5mpg on the highway with an empty trailer easy.
Finally had some time to work on my front end project.
Please tell me the switch to turn on that light bar is this one? Lolea317e08aa6ca7359268b27cfe8dc390.jpg
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: jorge_dropkick_rangel
  • Like 4
U should definitely try this with 93/91
I get like 14mpg with my empty utility trailer (16'). Average 11mpg loaded down. I also drive it like I stole it so I'm sure that doesn't help
Even light output with sharp cutoff using stock projectors and adjustable offset LEDs!!
DROPKICK Edition
You mean this button? lol Surprising enough because of all the holes in the octopus it doesn't block very much light bar light.
  • Like 6
Anyone know what colour wire the dome lights might be? I'm hoping to tap into it so I can add some lighting for when I open the doors. This is the best I could find, and I'm still a little confused.
http://www.silveradosierra.com/electrical-manuals/2014-silverado-wiring-info-t228266.html
NitroDatsik? You're kinda the lighting guy, maybe you can help me out. Thanks.
