12 minutes ago, DirtyAndy said:
Yes, it was extremely windy in IL today. When I saw the preview of your reply it left me wondering if a tree fell on your truck. Glad that wasn’t the case!
No it must have fallen across the road right after I drove through, was in my in laws house for about a minute and came out and saw the tree
Got the truck back last week after $6500 in pdr work. Gave it a good chemical guys wash and carnuba wax today.
Plasti dipped my mirror caps to match sort of
Getting them off was a PITA but i think it made a difference
Now just waiting on my tpms
Sensors so i can install the 22x14 wheels i orderedae1aee93abe567c9b3fc2b3589eea49b.jpg
5 hours ago, ShubiSnax said:
Morimoto D2S 4.0 35w retrofit, Morimoto LED fog lights and All-Terrain inner grille.
Finished up just as it started raining.
I'm going to need a review of how you like those projectors.   Been contemplating upgrading my factory ones to these.
Initial thoughts are, wow these are bright. Factory halogens don't even compare and I can already tell it's gonna take some time to get used to the dramatic cutoff.
After some driving last night, I decided to aim my headlights a bit lower than stock. I just feel bad coming up over a hill or hitting some bumps and my HID's are most definitely blinding oncoming traffic.
Also, I've noticed that right around the cutoff point, the light has a purple color. I really notice it when white road signs light up purple. My bulbs are Morimoto 5500k.
As far as installation, it couldn't have been much easier. Phil from Fastheadlights.com was very helpful and recommended the Hylux ballast over the Morimoto. There is no wiring to the battery and no relay harness. Super easy.
It was a bit time consuming, and the hardest part was cutting open the factory lights, but I took my time and everything turned out great.
Driving down a dark country road with the brights on is just about the coolest thing ever haha.
IMO, the LED fog lights are a must-have when you have headlights this bright.
Hope this helps!
Finally got around to finishing up my Eibach pro truck lift kit install video. This video applies to pretty much any strut/shock replacement. Complete so-able in your garage with the right tools!
[/url]
Waterfowler 41’s Youtube channel:
https://www.youtube.com/user/brittmork
How are you liking this kit? First time seeing it
Washed and put ceramic booster on to really bring out the shine of the ceramic pro.  Like a black mirror :)
Edited by 18Midnight
  • Like 14
Removed the lower valence and replaced it with a custom valence made by a member from another forum. 8decc9d07ca2c6ce55a6164c55c818fe.jpg42fbb2739b1f8516b2461229861e59f3.jpg
Sent from my Pixel 2 XL using Tapatalk
  • Like 3
Installed these Rigid DOT fogs that have been sitting in the box for over a year. After awhile, I decided that I wasn't a fan of what they'd look like. Recently I said screw it, and worst case I just remove them if i don't like them. These things are bright, and I think the look could grow on me. What I really didn't like was how the kit comes with stainless steel carriage bolts that can be seen behind the light, so I swapped them for black ones. Hopefully they don't rust or I'll have to suck it up and install the stainless ones.ea857745ecff8d2d1e115d61e86cef45.jpg8551a69024d4a6fcffafa979d018b815.jpg93258dcba4de3174c8eb67e5bfbcf500.jpg6b4d01d2495ac6837cd074b589600c11.jpgd07c9c77fa74a8a757f3ed1e3a945fd9.jpg
  • Like 4
Looks awesome!  I’m hoping for some time to do some paint correction and put on my cQuartz sometime. Whenever I get some time from detailing customers cars...  lol
  • Thanks 1
The truck rides and handles great! It was worth the money and time to upgrade. I had a block rear shock so it was time to upgrade. The lift is perfect for my daily driver. I went overboard in the past on monotube shocks on my f150 when I installed the ranch’s mt7000’s. These eibachs are a world of difference.
Waterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
anymore info these pads and rotors?
Bought them from rock auto. Did my fronts for around $95. Will be doing my rears after winter. They perform as good if not better than OEM with the added benefit of the rotors ability to resist rust so they look good behind my wheels still.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   4 Members, 0 Anonymous, 614 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
