anymore info these pads and rotors?
Bought them from rock auto. Did my fronts for around $95. Will be doing my rears after winter. They perform as good if not better than OEM with the added benefit of the rotors ability to resist rust so they look good behind my wheels still.
Waterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
2015 Silverado
OEM HUD installation.
5db19f6b992f0ffd13655bcd137b9d52.jpg08c03389cde833607829232f0e47de0a.jpgb773394bd9795325882e1d01d5ceec11.jpg5c29d0996601fb5240892dbf51a8ba43.jpg38c46c6835ace80dc580dc579ba783b0.jpga75353eb22e6574f10ff2ba1c146fb93.jpg
HUD loos much better in person than pictures.
Do you have more info or a how to on how to do this or a link to an existing thread if there is one. Thanks in advance
Sent from my SM-G955U using Tapatalk
2015 Silverado
Do you have the kit # for it? I’d love to have it done to my SLT. That looks awesome
Sent from above
It has never been done before., I took on the challenge and with@pgamboa@jadscoop help I was able to pull it off. I’ll do a write up but it’s going to be a long one since there’s a lot of modifications needed for the HUD to be installed “OEM factory like”
Sent from above
No kit. I built everything from scratch, Phil Gamboa built my harness and@jadscoop created the new cluster visor. Since our 14-18 were never meant to have a HUD, every part had to be modify and built.
  • Like 4
No kit. I built everything from scratch, Phil Gamboa built my harness and[mention=191422]jadscoop[/mention] created the new cluster visor. Since our 14-18 were never meant to have a HUD, every part had to be modify and built.
Impressed!
Sent from above
.. hit 2000km in the truck today.. I know the DIC estimate isn't 100% accurate but I'm still really loving the gas mileage in these trucks.. especially considering my F150 was in the 18-20 l/100km range
9.6 l/100km = 24.5mpg
 18 l/100km = 13mpg
  • Like 3
Finished up my video install of the DeeZee hex series runnign boards.  Doubt it warrants a whole write up on how I installed them as most every running board mounts the same.  The Hex mounting of these bars is pretty cool and gives the board a unique appearance in this world of round running board.
Overall I am happy with how these went on I only wish there was a way to reuse the plastic covers from my stock running board to cover up the Deezee brackets.  The brackets by themselves look so dinky.  I know the OEM brackets are the same style of metal bracket but the plastic covers gives it a nice finished look.  Anyways big appearance improvement over my old board.  Matches my bumpers and wheels much better!
The kids approve of the new boards. They hang lower so it’s easier for them to climb in.
Edited by Waterfowler41
On ‎10‎/‎8‎/‎2018 at 6:40 AM, 2017_whitez71 said:
23431457
This looks like this is just the front left. Do you have the part numbers for the front right and both rear doors? Thanks!
Order 4 of them.  All you need is the knobs, the rods don't fit our trucks.  The knobs unscrew of the rods.
a while ago in this thread one of the guys showed some pics of some new hitch covers he got from kempter kustoms
they looked AWESOME so i checked out the link above and found a part of the webpage where you can order a custom hitch cover.  so then my dilemma was 'do i just order the awesome boba fett hitch cover or go full custom?'...  well, i went full custom.  after a few emails back and forth i placed my order and today my hitch cover showed up - it's AWESOME!!!!
this is my men's hockey team jersey (i've run this team for 9 seasons now - just a great bunch of guys - they are like brothers!)
and this is the hitch cover that showed up today....
what i LOVE is that they left the eye 'hollow' and there is a cutout in the back of the hitch cover so i can add an LED.  i'm going to use a red LED and wire it to my brake light!  ha! ha!
  • Like 12
replaced the black window trim with chrome, replaced the rectangular steps with the 4" round ones and replaced my 18"Z71 wheels with some 18" Sierra/Yukon wheels.  Unique stock grill replacement coming soon
  • Like 4
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
