I may be in the minority here but I love that opening as a hand hold for hopping in the bed.
Waterfowler 41’s Youtube channel: https://www.youtube.com/user/brittmork
I agree. I use them all the time for that same thing.
Sent from my SAMSUNG-SM-G890A using Tapatalk
4 hours ago, Nick The Great said:
It's crazy these trucks don't come with that.  The front ones are covered.  :confused:
But yeah . . . they'll go down flat.
The front ones are covered but if you want to use them they are scored and can be cut out with a utility knife.
As others have said the back ones are open because they are handholds for use with the corner bumper step.
I have the back fillers installed since I have a tonneau and I can tap them down with my hand easily.  If I take the tonneau off and want the pockets open I can get my fingernail or a small tool under the lip of the plug and pop them out.  I bought mine from the original designer who owns the patent.  He laser-scanned the openings so the fit is perfect (there are cheap knockoffs out there that don't fit as good):
https://railcaps.com/
I would like to find a set of these that are spring loaded. Keep the junk out AND hand hold when needed! :thumbs:
I usually keep a small can of bug dope in one side just in case I forgot it and am already in the woods.  I Always use them to grab onto as well, or stick a fishing rod in if we are bank fishing.
I mounted a Derale 13005 above the secondary battery tray for a remote trans fluid filter. Also gutted and plugged the trans thermostat. Going to drop the stock pan and weld a 3/8" bung and plug this weekend.
30 minutes ago, STRMTRPR said:
Used $18 CDN Amazon TPMS tool to teach the new pressure sensors in my winter rims. Worked great!
teach new pressure sensors?
He probably meant to program the new sensors to the truck.
Sent from my SM-G955U using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
