17 minutes ago, CKrado said:
I love the boost auto mirrors. I even had 1A prior to these and the part that bothered me the most was not having the red blinker on the glass. That may not bother some but I wasn't a big fan of the blinker design from 1A. There are two things that boost came out with after I got mine that I wish I had and that's the power fold feature and the high output cargo light. The customer service at boost auto was second to none as well. The owner called me after hours one night to help me trouble shoot an issue I had. The issue was on my end, nothing to do with their product but he was still there and willing to help.
Sent from my SM-G955U using Tapatalk
Awesome, thanks for the feedback.  Yeah I don't really like how the blinkers stick out on the 1A Autos either.  Looks like I'll go with the Boost..............Thanks
On 11/24/2018 at 12:52 PM, CKrado said:
Nothing major just added some decals to the front doors.51b02db51363ef842c5ac9c09f89c811.jpg
On 11/24/2018 at 2:53 PM, CKrado said:
I got them on amazon. The ones that are on my truck are the medium size
https://www.amazon.com/dp/B01HPF50S4/ref=cm_sw_r_other_apa_5vD-BbA1WYGB50cbd318c7569d4b02babf104c25c899c.jpg
:thumbs:  Looking at getting a pair of medium sized, grey ones for my ME.  Your flags are where they put my Z71 badges.  Debating on moving my Z71s down & placing the flags above, or just putting the flags slightly above or below the badges.
Just a heads up for anyone putting vinyl on paint. In my experience with GM in the past any vinyl or magnet left on will cause noticeable marks from washing around the outline and also tend to fade different if left for a long time.
Assuming it's a "permanent" mod then whatever but if you plan on trading in frequently it's best to keep to glass.
Edit: meant to add that I'm looking to add these to my paint as well. Thanks for sharing the link!
Edited by Penguin VII
  • Thanks 1
Ordered a set of Hylux D5s bulbs in a 5000k 35w. I’ll get pics when I get them to compare them to the factory. I found them on sale for 129.00 so I figured I would give them a try.
I also considered placing them right below the mirror since they were close to the same size
Found a GM borla muffler on the cheap from a local guy and borrowed a wielder from a my father-n-law and went to work on it. I didnt like the factory exhaust exit so I chopped it just over the axle put a 14 dollar chrome tip on it. Total cost for everything 64 dollars.... 8c89c606a5eb991c105c8a21c4398d65.jpgc9246b8803c6462b558dd6df0ba30918.jpg88a3e14e39c3b90e0b52e791d862b04e.jpg
Sent from my SM-N950U using Tapatalk
  • Like 4
Nice, wish I had a welder or access to one!...here is a cheap way to cover those frame holes if you’re interested. Keeps junk out at the very least.
https://www.amazon.com/dp/B01N94IGOG/ref=cm_sw_r_cp_api_LqZ.Bb1HVT7WF
Either way that’s a great piece of work ?
Edited by SS502
Does this count?
Where can I find this?
2015 Silverado LT Midnight Edition
4.5” CST suspension lift
59 minutes ago, CajunFries said:
Does this count?
Extended range or just for looks? Don't quite know why you'd want to make the font larger but hey.
Just for looks.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
