Ami styling billet grille emblem installed. powder coated black. And matching the grille almost perfect. I think its a great product since all the abs material in black were well over 100 bucks. I paid 53  shipped with a 20% military discount.
Added some Anzo lights with Titan Led's
Only thing I don't like is that the white led does not automatically come on like it did on the factory lights.
You have to turn the parking lights on to get them to come on.
Selling my factory 2014 GMC Sierra Denali headlight capsules with Klearz, Diode Dynamic Switchback Led's and Morimoto HID headlights.
On 1/6/2019 at 7:28 PM, BillK01 said:
Yes...two 21/64 holes on each side.  Pretty simple install really....about 30 minutes or so depending on how particular you are.
btw....if anyone decides to get one and you have a BakFlip MX4, I can confirm you do NOT need the optional spacers they sell for tonneau cover users. Mine cleared fine with plenty of space to spare without using them.
Also clears the Undercover Flex with no spacers as well.
18 hours ago, DirtyMarcus said:
Thanks!  I take it you bass fish too.
for sure!!post-161090-0-14659200-1484837920_thumb.jpgpost-161090-0-18095200-1484837955_thumb.jpgpost-161090-0-27224000-1484842785_thumb.jpg
  • Like 8
Those are pretty sharp!!! How are the headlights compared to the factory ones you replaced?
not as bright as the hid kit i was running in the factory lights
I have replaced the halogen lights that anzo supplies with some led.
They are alot better but thinking about trying the hids.
The LED's in my 18 (and 16 that I had) are so much better that the HID's that were in my 14. Don't think I would ever go back to that type of light.
Put in my 9pc bull ring kit finally! So far I like them alot.
Look great, good job!
Sent from above
Finally got to mount my Fifteen52 TurboMacHD on.
The truck is pretty dirty tho....
15 hours ago, txrangersfan said:
Installed a passenger seat lift kit.  Added 1 1/2" inches to the height...
Look's good - Any info on lift kit ??  How Short or Tall are you ?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
