My bad was talking about the bow tie. Looked funny on my phone. . Looks great on the puter.. nice job
Yea it turned out funny in pic but it to cold to get a different one lol
My truck got a new radiator today! Good ol' warranty work.
Noticed some green snow on the front of my truck yesterday and a potent smell of coolant...dealer is taking good care of it.
How easy was it to tap into your reverse lights?
Remarkably easy. Simple quick connector. I didn't use the module by the bumper, I ran a write straight to the wire on the taillight
Got plenty of work done on the truck today! So here's a few pictures and what is different incase you can't tell.
So let's go from front to back of the truck,
I removed my failed HIDs and replaced them with the OEMS halogens, man did I forget how lousy these things are. Honestly, the DOT pods are better than the OEM headlights IMO.
Next I went ahead and cleaned up the engine compartment of some of the wiring I have added. This mainly consisted of the HID harness and the harness for my light bars. I wired in a new wireless controlled harness for the lights and man is it cool! I think the main "cool" factor centers around the fact that I now have a few different strobe patterns that I can make the light bars flash to, and I was able to program the on/off function to one of the garage door opener buttons in the truck.
Video of strobe patterns:
hey man, what did you end up using for the wireless remote harness?
thanks!
Put and extended cap on my drivers headlight after testing the fit. Adjusted my dim light bar behind the grill and found out why my one fog light isn't working.
Here's the damage. There's also a dent/scrape to bare metal on the middle of the hood. Been quoted $4500 - $6700. That's for two new bumpers, fog light assembly, new grille, new plastic pieces above and below the bumper, and fixing the dents and refinishing the hood, passenger door and fender panel.
Edited by jonny24
I would just get insurance to cover this one if I were you. I don't know what your overall standing with your insurance is though.
That really sucks, man. I feel bad for you. I guess if you want to look on the bright side, you could buy some cool aftermarket bumpers with the insurance $.
If it makes you feel any better, I had a pretty major accident with my last truck when it was only 2 months old. I had it repaired at a reputable body shop and never had any issues with the repairs in the 11 years I owned it. Good luck.
Glad your ok. If it makes you feel better check out the edmunds video of the sledge hammer to the new f150 and the cost of fixing it
Installed some new Bosch Icon Wiper blades. Nothing too exciting. I was probably too excited in how easy they are to change out. Push one tab and slide out. Not that the older U turn hooks were difficult, but this was too easy.
Texas - was the part # the Bosch Icon 22OE?
I'm going to change the name of the thread from "What have you done to your '14 today?" to "What have you done to your K2 today?" considering they have 2015's out now as well. Thanks for the understanding!
  • Like 4
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
