Installed 2016 LTZ Tail Lights on my 2016 LT truck! 25c05302f61333599fa30faa683044fa.jpg
  • Like 5
Got it for $600 shipped on eBay. But I ended up getting an line harness with resistors from Gen5DIY. $80 for that.
Installed the Diablo i2 tuner on Tuesday and my Nfab nerf bars today. Ahh it's been a great week!!!7869afdd7ac60fbf62614795690f76ea.jpg
Edited by mmwest
well...you guys did it. fully scared me away from the RC 7.5" lift lol.
returned that today ha
luckily i never opened it/installed.
mcgaughys 7-9 ordered instead
Well done!!
-tapa
Nice I think the 8 inch setting with add a leaf for better payload and maintaining rake is the best setup but going 9inch or 8 level is pretty badass too.
the track width increase on the 7.5" rc really did me in. no shot im going to spend all this money on new wheels and tires and the lift i want and NOW need spacers to the get the rears matching the fronts
well...now i know my next mod lol. completely forgot the LTZ's got different tails
I am not a professional but have been told one should never use spacers in place of an honest offset. The rear tires do stick out less which is normal because the axel is shorter by design on all trucks. Your best option for getting them to match (which is not needed) is to use a wider offset on the rear than in the front.
exactly yup. i agree with you there.
from MCG website, keeping the truck at 8" will keep the front track width increase to a minimum and wont be too noticeable with my -24 offsets. (i hope)
i did do the add a leaf so i can keep the truck level at 9" like they suggest, however, with this setup it'll increase the tw the most. even at 9" though, tw still wont be affected as much as the rcx wouldve at 7.5....i made the right choice returning that damn thing
Edited by jerseytaylor
When you do this, if you don't already know, Gen5DIY has a harness that'll adapt to your 2014/2015 with the resistors wired inline. Since my truck is a 2016, the connectors are the same for me but still bought the harness so I didn't have to tap into the existing harness wires.
do you have any insight with the 2016-17 led tails? or is that a whole other beast..
i suck at wiring chit up lol
The harnesses for the 16/17 tail lights are different between the LED and Halogen. On the tail light side, one 4 pin connector drives the brake, and signal. Then the traditional socket for the reverse.
On the other end, (that plugs underneath by the spare tire), that connector is the same between the two. The harness that Gen5DIY provides makes it plug and play. You just need to mount the resistor. I am good at wiring but didn't want to spend the time to figure out which wires to split into. I really don't like to splice into an existing harness, especially when there was a chance for a dealer BCM program to correct hyper flash. Since a reprogram was a no go, I kept the harness and plugged them in inline.
Edited by pgamboa
so that Gen5DIY harness goes from the existing harness by the spare tire to the taillights?
Yep. When I bought the tail lights, it came with the harness already. This harnesses plugged up underneath. However, since I had no resistors, they hyperflashed. Gen5DIY makes two types of harnesses. One for 14/15 trucks - that adapts the 16 harness into the 14/15 connector underneath (with resistors pre-wired in line) and one for the 16 trucks with the resistor pre-wired.
Edited by pgamboa
There is only 16-17 LED options. Was no LED in 2015 or previous years.
It is just one beast.
You can also check out Spyder lights for direct after market replacement. I would review their products as excellent quality and a much better price since they are not 'OEM Marked up'. I am running the Sierra version of both their head lights and tail lights they are plug and play but I am running a GEN5DIY harness on the headlights to enable LED strip only DRLS. Gen5 stuff is great and Jarrod is a modern day wizard.
http://www.spyderauto.com/product_list.php?car_make=Chevrolet&car_model=Silverado&car_year=2015&cat=Tail%20Light
Edited by Alpine Truck Life
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
    • While waiting for parts I have been working on installing the AC compressor, new accumulator, and orifice tube. Also changed out the high side ball valve (original). The orifice tube that was in there wasn't too bad. Slightly dirty, a little bit of junk, but not blocked. Glad I changed it out.   The accumulator, which should have been a 5 minute job, may have just burned $50. Put some PAG in it, wrote the date and mileage on the side, fresh o-rings and gooey'd up the threads and rings with Nylog. Got everything connected and snugged and was going to vacuum down the system, and....   My manifold gauge won't fit on the port. It's not an R12 service port. It LOOKS like an R134 service port but the diameter is a hair too large. There's a sticker on the accumulator that says it's designed to be used with R12 and R134a systems only. So it's not R1234yf. Even if I reduced the diameter slightly with a file, the shoulder on the port is too large so the quick-connect valve won't lock on. I'm stumped. It's going back, and 50/50 on if they'll give me a refund.   Also, I did a fuel pressure test.... Key on, the gauge spikes to about 60psi and quickly bleeds off, like 2psi per second. The fuel isn't going into the plenum, no smell, starts fine, so I'm guessing there's a bad check valve in the pump and the fuel is just draining back into the tank. oh, hell. But, it shouldn't be a problem, pump primes just fine and the truck starts right up. It just means I can't really ever use fuel pressure to verify a leak at the injector or intake.
    • Got this yesterday out of nowhere. Truck is a 25',6.6 gasser with 8k miles.  Only semi anomaly is that the truck had been sitting, uncranked for 6 days. Elec Stability Control showed immediately upon cranking, not while driving. No drivability issues, just the message. Battery didn't seem to be weak when cranking over.  I drove it, killed it, let it sit a few hrs with no avail.  Truck is 100% stock. No damage.
