'Interior Driver Assist Handle'
tenx82
Just installed my shale colored drivers assist handle in my 15' Silverado with the cocoa dune interior. Fit and finish is perfect. I ordered mine off Amazon and it came in two days even though it wasn't supposed to get delivered for four.
A couple tips I didn't see mentioned. When removing the plastic retaining clip on the original trim, you do not need to cut it. People mentioned zip tying it, but if you look closely, the metal retaining clip holding it to the A pillar actually has a slot for inserting the clip on the free end of the tether. So it basically just snaps back into itself, which is how I did mine. Also, since I didn't want to cut the clip, I was careful to detach it from the original trim carefully in case I need to revert it back. To remove it from the original trim, you just need to push in the black plastic tab that goes through a small slot on the original trim piece. When you get in there you'll see what I mean. You push the tab down and through the slot and it comes completely free intact. You then just stick the extruding metal clip on the free hanging end into the opening on the metal clip holding it to the A pillar. It's now secure and out of the way. I added a photo below of the tether secured to itself when I was done so you can see what I mean.
I did however need to cut off the triangular plastic guide on the new piece of trim. With the guide there, the new trim would not line up nicely and give me a nice flush fit. I just used metal snips and snipped it off - took 5 seconds. Once off, the new piece fit nice and flush. I figured that guide is not needed since the bolts that mount it are basically right on either side of the guide and it would add nothing in the way of stability or function.
Once bolted in, everything looks prefect - better than some of sections of trim in the back I haven't even touched. Huge improvement for me, and my leather seats will thank me for it. Got it on amazon for $51.60 with free shipping. Search for: 23285089f65c6216ca308cbcbd4d65d94d444384.jpg6f3de48bbdaae71a2670e02c53b33890.jpg
Does the original piece just pop off? Or how does it come off don't want to be wrecking anything or even worse setting off the airbag. Thanks
  • Replies 480
From post #97...
Yep, fit perfect. Install is really simple.
1) Sitting in driver's seat, work fingers under top part of stock trim piece and then pull straight back. Two tabs holding trim will pop.
2) Between panel & pillar, there's a black tether so the panel doesn't go flying when the air bag blows. Cut/clip it as close to the pillar as possible.
3) Slide new handle panel in, bottom first, then top. The new handle panel has a big plastic alignment pin in center to help you position it correctly / line up bolt holes.
4) Insert and tighten bolts. Close bolt hole covers. Enjoy handle!
It really is only a 10 min install.
Installed one as well. Amazing this just isn't a factory default.
Just installed mine tonight too! Tried to save the tether off the original trim piece but couldn't get it to release for the life of me. Finally cut it and installed the new part with handle.
I got mine when I first got the truck and use it all the time. It should come with the truck in the first place like all the other vehicles on the market.
installed one never use it ,not the right feel when getting in
One is on its way and should arrive this Tuesday. Don't understand the tether or clip thing. Hope more is clear when I look at the instruction and take the original trim piece off.
Does anyone know where to find the color code to make sure I get the right one? I'm guessing the a pillars are only light gray or tan?
This one is for black interiors
http://www.shopchevyparts.com/interior/2015-sierra-1500-driverside-assist-handle-package-light-gray/23285090-p-92282996.html
This one for Cocoa Dune interiors
http://www.shopchevyparts.com/interior/2015-sierra-1500-driverside-assist-handle-package-shale/23285089-p-92282995.html
Sweet. I was scared there was gonna be a bunch of diff colors and I ordered the wrong one. Glad to see I didnt
Got this popped off and installed In about 5 mins. So glad I found that they made this.65d2fbbc9f76d631cf2408c0ab617512.jpg
Is there something wrong with the assist Handle I got, part # 23285289? Does this make the Air Bag non functional? Or does the bag just bust through the plastic and whatever plastic pieces that are not held on by the bolts go flying around in space.
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
