'Interior Driver Assist Handle'
tenx82
  • Replies 480
I give up. This is the second handle I've tried and it just doesn't line up without leaving a gap at the bottom. There's no other way for me to line the two holes up without having the gap. It's gonna drive me absolutely insane every time I get in the truck! Is anyone else's like this?7d0badd4db7104010a92b216f3e5b8d5.jpg
Sent from my SM-G930V using Tapatalk
The bottom edge should slide between the speaker and the pillar. The bottom should be put in first, then the top.
Oh I know, when I do that, the only way to line the holes up for the bolts is to then pull up on the handle to line them up. When I do that, I'm left with the gap at the bottom. I don't see anyway around it.
I'm starting to think that the mounting holes aren't lined up correctly on my truck. But it's welded to the pillar so I can't very well move them.
Upon further inspection, now I'm pretty sure it's the dash thats "sagging in that corner. I can fit my hand in there and pull up a good 1/2 inch. If the dash would stay that way it would then hide the gap. But how do I make the dash stay in the upward position? Shove something underneath it?
Just send me the handle then! Lol. I'd try and remove the whole front panel and try to re-seat it. Maybe it's off a little and causes it to sag in the corner like that.
I installed the handle on my 2014 Sierra last week. After I got it on, the exact same thing happened. There was a gap in the exact spot as yours, I took it back off and looked at it not sure there was any other way to get around the gap I almost boxed it up and sent it back. But upon trying again you need to install it back making sure you're lining up the bottom flush with the edge of the dash. Once you get the bottom lined up without the gap you can snap in the top but as you do, you need to keep some downward pressure on it and somewhat rotate the entire piece slightly clockwise around its axis towards you (this will make a small gap between the top edge of the molding and the glass on your windshield (which makes a gap there but is impossible to see). Then holes will be very slightly misaligned with the holes on the molding being a little further down toward the dash than the holes in the metal brackets. The provided screws will go in no problem and once fully tight the gap will be gone I had to mess with it a few times but it will work just keep at it.
paint the handle piece black and it'll hide the gap. I didn't have a gap on mine but the grey pillars sitting next to the black seats drove me insane, so now all my pillars are black. Ceiling is on the eventual list to get redone black
I almost think your speaker grill is what the issue is.
That's why the handles are not fitting right.
Just bought one of these yesterday. Should be here early next week. Had one on my last truck and definitely miss it.
To remove OEM trim and install new one with handle;
  • Wash Hands
  • Grasp the upper section of trim molding using finger tips near intersection with headliner
  • Pull back upon the trim with a gentle yet solid light jerk to disengage it
  • With the trim molding pulled back approx 3" reach behind it and disconnect the wire clip holder
  • Remove trim
  • Remove the snap in bolt covers from the new A-pillar trim by pressing in on the snap holds from the inner side and set aside
  • Position new trim molding in place starting at the lower end where it intersects with the windshield and top of dash
  • Run your finger along its vertical edge to pull the weather back and to position it so that it lays over/covers the edge of the trim molding I
  • Insert bolts and tighten
  • Insert snap in bolt covers and your done.
Not that it was hard but the instructions helped. Thanks
For anyone interested I bought mine from a GM dealer on amazon and was $42 with free prime shipping. Not sure if good deal or not, just bought it since I was buying something else from amazon and had a gift card
what paint did you used ??? how is it holding up on handle ?
    RyGuy43
    RyGuy43
  • Who's Online   1 Member, 0 Anonymous, 494 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
