You need a reset tool which you have to use even after rotating the tires. I plan on buying one after the 24,000 mile maintenance warranty runs out. The tire place might have one but if not just go by a dealer and maybe they won't charge just for a TPMS reset. Only takes a couple minutes.
Thanks!
All you guys that switched from the factory P tires to taller/wider sizes and got stuck with LT tires, what's the ride like? I'm leaning towards sticking to a P tire but wouldn't mind switching to LT if the ride isn't too bad. My truck is my DD so I keep that kind of stuff in mind.
I didn't really get stuck with an LT tire I wanted it. I didn't notice much of a change in ride quality… I just prefer an LT over a P rated tire…
22" Replica Denali Wheels
305-40-22 Toyo Tires
do you have any rubbing? any offset/lift, etc??
I went for a clean look with these 22"s
what tires? and sizing?
I put about 10,000 miles on the stock SRA's before moving to my Duratracs. I ran the SRA around 36psi cold, I now run my DuraTrac's at 40psi cold (rated for 80psi) . I've found the ride to be slightly stiffer but actually prefer the ride with the stiffer side wall- it also makes mounting curbs in NYC far less nerveracking.
20 x 9 Fuel Maverick wheel +20mm offset
305/55/20 Nitto Terra Grappler G2
2 inch Rough Country Level
do u have any rubbing issues with just a 2" level?
It does rub the fender liners some . bottoms out a little when hitting bumps . im going to be raising it up a inch or so this weekend so it wont bottom out as bad and rub .
I went from the stock 275/55/20 SR-A tires to 35/13.5R20 Toyo RT and haven't noticed a difference. There's an in tial change in feel in your butt but after a couple hundred miles that goes away.
Stock!
Anything I've done to this truck is 100% reversible. When I sell it in two years it will be as stock as the day it left the dealer!
Edited by Dropsix
Finally pulled the trigger on rims and tires. Fuel nutz D251 20x9 with +20 offset. Tires are nitto trail grappler 295/55. Truck has a 2" level haven't noticed any rubbing as of yet. I think there might be some minor rubbing at full lock on the sway bar. Also tye wrapped the fender liner back just to be on the safe side and give a little more clearance.
Edited by Cody16
  • Like 4
Beautiful truck sir. I've always loved those wheels. I doubt I'll ever get rid of the stockers on mine but if I do those would be the ones to replace them.
Man, that looks good! Like those wheels. You can post as many pics of that truck as you want. I won't complain.
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 1,628 Guests (See full list)
