Shocker....Traded a member for wheels/tires.
2015 Sierra 1500 4WD
2.5" Leveling Kit
1.5" Zone Body Lift
OEM 22x9 +24 CK158 Wheels
325/50R22 Nitto Trail Grappler MT
No Trimming / No Rubbing
I also have a set of Nitto Terra Grapplers 285/55R22 and I'm on the fence about what setup I'll run, but here it is for now with the Trails
E2087E2F-F960-43A1-92C6-EB6354522A06_zps
  • Like 6
2.5" Leveling Kit
1.5" Zone Body Lift
I think it looks great!!
Got my 24X14 American Force Burnout with 37" Toyos put on today 3f6e67b09d0f7d34f84d09511fe693e7.jpga62c38797bef804adb425d4222abcfd4.jpg7d117eb85af6b74d274d5fe78f62e23e.jpg
Edited by Clint D
  • Like 9
Looks good!! What's the offset of the wheels?
thanks bro, and I think they are -44, plus I have 2" adapters
Edited by Clint D
Fuel Coupler 20x9 +1 offset
(On factory 275/55/R20 until my truck is lifted and i can fit 35x12.5's)
I actually like the way it looks with the OEM tires. Gives it a "street truck" look which i have no problem staying with until i can get it lifted.
They stick out maybe 1" from the fender, perfect look IMO, I love them!
22x10 Fuel Nutz
35x12.5 Toyo MTs
Love this setup! I prefer 22"s myself. Wish i could run a 35 on my 22" setup but i need more lift than just a level. I managed to cram 33.3" with my level tho. What lift are you running andis yours 4wd?
Thanks! I love the 22's. Would have gone 24 but you can't get 35's with a 24. At least not an MT. I've got the RC 6" but added Bilstein shocks and struts. Yeah it's 4x4 - notice the chrome decal on the fender [emoji39]
Yea im looking at it on my phone and missed the 4x4 sticker on small screen lol. Mine is only 2wd, as itll never see anything but asphalt but i still love the look. Thats why i went with a nitto ATs as i think in my case, its a happy medium. But yea man, i dig that truck. Looks killer
So the Bilistein shocks and struts is an "upgrade" with that kit? Do you find the ride similar to stock? Love those 22's, very nice look.
Sent from my iPhone
Sent from my iPhone
Absolutely. The RC rear shocks are not very good and since the truck has a lot of miles I decided to do the struts too. I think it rides better than stock. Even had a friend ride with me and he thought it rides better than my Infiniti. Thanks! I think the 22's are great.
2.5" Leveling Kit
1.5" Zone Body Lift
Looks amazing. Can you take some pics at full lock? I can't imagine this doesn't rub the sway bar at full lock, but if it dosen't you just gave me new hope for running the 325/50/22 Toyo AT2s on stock 22s.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
