25 minutes ago, mrskiff said:
305/65r18 BFG KO2
Sent from my SM-G973W using Tapatalk
How do the 305’s fit? Any rubbing? Have to do any trimming?
Had the zone offroad fender trim plates installed to clear them3e6c0b1620516713c7dd49a07b3c3f6d.jpg
On 4/20/2016 at 3:55 PM, Rickbo said:
I had this wheel and tire set up for a short while didn't like the way it looked so I sold that set. Was Nitto Trail Grabber 295/60/20 wrapped around a set of KMC XD 20x10 Monster 2...
I'm now running stock all terrain 20s wrapped around a set of 285/65/20 BFG KO2 and I absolutely wouldn't change a thing. The left is a a 4.5 inch suspension lift made by zone
What was your offset? I really really want the Zone 4.5 as well but I'd like to stick with 18's because I have some cherry Cooper AT3 I can use. However, I would need at least a 0mm wheel and that would push my tires outside the fender quite a bit like you mentioned.
20's can help combat that ultra wide front stance issue but then that would put me out of budget, needing new wheels AND tires.
On 3/8/2019 at 8:45 AM, Kubs said:
Just recently switched from the stock 18's to these Methods.  I love the way it came out!
Method 315 17x9 -12
Bridgestone Dueler A/T Revo 3 P285/70R17
47206942322_5efac0408c_k.jpg2019-03-02_12-59-18 by Mike Kubiak, on Flickr
46344289245_244779585e_k.jpg2019-03-02_12-58-13 by Mike Kubiak, on Flickr
40294091993_dc70219131_k.jpg2019-03-02_12-59-39 by Mike Kubiak, on Flickr
47258839421_2e991a4696_k.jpg2019-03-02_12-59-58 by Mike Kubiak, on Flickr
Are you on stock suspension?
The only changes are Bilstein 5100 shocks with the fronts on the highest setting, and then a 1/4" spacer on the bottom strut mount for an additional 0.5" lift.  Im around 2.25" total level on the front, rear is all stock.
On 4/29/2017 at 11:57 PM, Rickbo said:
2016 Sierra All Terrain 5 inch Bracket suspension lift from Rough Country! I have to say I absolutely love the lift the truck rides like it did the day I drove it off the showroom floor!! 295/60/20 Nitto Ridge Grappler's, wrapped around a set of Moto Metal 970 Gray with Black Lip 20x10-24!! KNN cold air makes for a perfect addition.
Any issues with the lift since you've had it? I had wanted the zone 4.5 but wanted to stick with 18's which would've pushed my tires out way too much with the needed offset and the way zones kit widens the track.
Hey guys new here , I wana do somthing new to my plain Jane 2015 Z71 , I have stock 18in rims with 275/70/215Ko2s right now . I want to go to the Michelin ltx m/s2 tires but want to upgrade to a 20in OEM chrome wheel. Will I be able to do this without a lift or leveling kit ? I'm new to this wheel game and need help lol thanks guys , also what else can I do to make this thing look new or better again lol I see all your trucks and they are so damn beautiful!!! Help a brother out
Edited by JGZ71
4 hours ago, jgraves13 said:
Ocotillo Wells?
Good eye. The opposite side of the same desert. Ocotillo by the 8 freeway AKA plaster city, near superstition mountains (about 10 miles west). Actually much prefer this spot to Ocotillo wells. Both for family type riding with little kids and high speed stuff with fast machines. A lot less people with a mix of families and serious off roaders/ experienced racers not much riff raff with the exception of a few tweakers here and there that actually live there.
Edited by kennerz
I'll have to make it over there sometime, never been out that way. We usually camp over by the Blu inn
I've been everywhere local in Socal with the exception of Gorman. Was  a fan of the dunes for years, but I have to say one of the must do ride spots is superstition mountain awesome mix of desert riding there.  I way prefer that over say Johnson Valley (King of the hammers). But plaster city/painted gorge is pretty cool if you like open fast and deserted and small technical mud hills. Ocotillo Wells has some attraction, but always see life flight every time I  go there, plus some jerk tried to steal my bike out of camp at 4:30 am last time I was there (this year).
20x9 0-offset Moto Metal mo970’s
295/55r20 Cooper Discoverer Stt pro
minor rubbing on the liner. Took off the mid flap and trimmed the Little Rock guard to the lugs on the tires didn’t catch it in reverse
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
