Last I checked when you tapped into the wiring to install subs on any 6.2 you'd get feedback because of the active noise cancellation these trucks come with. Has there been any workaround this yet?
How did it go for the guys with storage boxes and the kicker?
I cut my box down with a gigsaw.... Followed the form of the sub box. It doesn't butt up to the sub box for fear of rattling. Just off by a hair.
Can you post a pic? Do you have factory or aftermarket like a du ha box?
I will try to take a picture later today....the storage box was installed by the dealer, so I assume it is GM's.
Hello all. I am new to the Silverado and just picked one up 2 weeks ago. I am looking at the amp/sub upgrade from shopchevyparts.com and was also wondering if anyone else has switched out their factory speakers also? I was looking at putting in Kicker 6x9 41KSC694 in the front door and Kicker 41KSC674 in the back door. Does anyone know what size the dash speakers are?
Thanks for answering my questions and for posting your thoughts and experiences of this amp/sub combo.
anyone looking to purchase this kit i ordered the brand new one from gm im in florida i wont ship it
Kicker 200 / 400 Watt Powered Subwoofer and Amp, Double Cab by Kicker® 19303115
whats it worth like 800?
Does anyone that installed this also have full coverage rear floor mats? I didn't think when I ordered the floor mats and now am concerned about how the sub will sound sitting on the mats vs the carpet. Worst case is I don't like it and just take a knife to trim the floor mat around the sub.
I have the full rear seat husky liner and haven't noticed any negative effects. I did put two hard foam spacers inbetween the sub and the mat to ensure there was no additional noise though.
Sent from my SM-G900P using Tapatalk
One more question to use that have the 6.2 and non bose system. Do I have to do anything with the sound cancelling aspect that gets added when you have the 6.2?
Edited by thetruck454
So, I bit the bullet and purchased the Kicker Powerstage Soundgate "kit" from www.shopgmcparts.com They had the lowest price that I was able to find and don't believe any of the BS from AutoAnything about pricematching... They don't do it. They try and use smoke and mirrors, but they fail.
Anyway, the install was easy. My strong suite is not reading directions, but the directions provided were actually clear and helpful. With the helpful information provided within this thread I was ready for the hard part of fishing the power wires through the firewall. That was the most difficult part. However, thanks to the other posters, I thought it went as simple as can be.
The install took about 2.5 hours, simply because it was cold out and I was in no hurry. Oh and somebody routed the cable to the sub woofer backwards. Remember, read the directions...
How does it sound? Frickin amazing. Far better than I expected. My own media is simply awesome, but what impressed me is what it did to XM. I wasn't sure how much it could help the compressed audio from outerspace, but it improves that 110% as well.
The best part about this way of doing things is everything is plug and play and you keep the factory look of the dash...
Andy
So is there no way us Denali owners can use this?
earlier in the thread, I believe somebody has used the Kicker Soundgate along with the factory subwoofer. Somebody correct me if I am wrong, you could use the same signal the factory subwoofer amp receives and split it to the amp of the Kicker.
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
