1990 silverado 2500 6.0l overheating problem help!
huntyr
So I am dumb and I mixed regular green coolant with my dexcool and didn't know gm did Dex cool, so there was a little muk from it and I did a flush and it cleaned and everything was good, few days after my truck started to over heat, I didn't let it get too hot and got a tow home, I did a new thermostate and that didn't do it my coolant is going up and down bad and then going over the reservoir cap while burbing it, and then overheats,told it was reservoir cap, so replaced that. then found water pump wasn't pumping water so replaced that, and coolant still doing the up and down and over heating, my one friend said air pocket mayeb but I keep getting cracked heads or gasket but no oil in coolant and takes a good while for it to get hot. I am very stumped and also go told maybe my radiator but not going to replace that till I know for sure. =/
There are many causes of engine overheating. By far the most common cause is air lock in the cooling system. An air lock is simply a pocket of air in an area of the cooling system that does not have an inlet and outlet path. Some engines have bleeder fittings to help remove the air. Unfortunately, those engines are normally in Japanese made cars.
Removing the air can be done by loosening heater hoses while filling the cooling system with engine not running. Generally you would disconnect the higher of the two heater hoses and then connect it back up once coolant appears at both sides(at the end of the hose, and the open side where the hose connects). You can also idle the engine with rad cap removed, and use the throttle to raise engine speed to about 3k rpm and then release it. This is sometimes referred to as "burping" the system. If there is air in the heater core, you can sometimes tell by feeling the temperature of the heater hoses. They should both be nearly the same temp if the heater is on. Also have the rad cap tested.
Keep in mind that with the cap off, the coolant will begin to boil at an earlier point than the temp gauge indicates. Straight water boils at 100 degrees C, adding anti-freeze to achieve a 50-50 mix raises boiling point to about 106 degrees C. This means that your engine will boil over at a very normal operating temp if the rad cap is either not tight, or defective. This also means that if the pressure in the cooling system exceeds the caps rating, the coolant that is pushed into the overflow or reservoir will be boiling violently.
Mixing the two different types of coolant is not supposed to be an issue. The "mud" you have in your cooling system is due to Dex-Cool all by itself. Nothing to do with mixing the two different types. You need to have a chemical cooling system flush done to remove all the "mud" from the entire cooling system. Depending on how much is in the engine, that may be the cause of your overheating.
In my near 40 years of mechanic experience I do not recall ever replacing a water pump due to it "not pumping". I have also never actually seen a pump that had failed to pump, or ever heard first hand from another mechanic that has seen one or replaced one due to not pumping. The only way it can stop pumping is if the impeller comes off. There is no pressure on the water pump that would cause the impeller to even slip on the shaft, unless the water pump is full of water, and the water freezes. The one time I have seen that, the pump still did not fail, but it did burn the fan belt off due to the water pump frozen solid. Once the water thawed, the pump started turning, and all the "coolant" drained out the 3 core plugs that were pushed out due to the freezing of the pretty much pure water coolant.
If the engine is overheating on the highway, take a good look at the inside of the radiator if you can. Look for blockage in the tubes of the radiator core. Also look at the cooling fins on the radiator. They should be not bent in such a way to block air flow through the radiator, and the fins should not be loose. If the fins are loose, it will be pretty obvious normally, and you will be able to push the fins in and out. Loose fins will require a replacement radiator. If your truck has a rad cap on the actual radiator, you will be able to see inside the radiator to check condition of the tubes.
I saw an impeller come off my buddy's '87 Firebird V6 once - was overheating and making a noise I can only describe as ... if you take a toy that has a wheel on it, and spin it faster than it was designed to go, and it suddenly goes out of balance violently & makes that "BZZZZ" sound, which nearly brings the wheel to a stop instantly. Every time he revved it, it made that sound ... and it was coming from the general area of the water pump.
Took a gamble and replaced it ... and when I took the back cover off, the impeller was just floating around inside. First and last time I had ever seen that.
This made me LOL
Me too when I heard that sound. I think I made some wise-ass reference about a matchbox car to my buddy ... :lol:
Ok thanks guys gonna take a look at the radiator and do your air trick
There is no trick in service information that says to do that , ( sorry Doug), it is just not done , you have to read up on how to bleed YOUR engine from a service information site , this is just not even near rocket science and I can't believe your having this many problems and throwing parts at it IS NOT COOL, !!!
Start again by taking it To a real garage
Serously .... Dude !!! Lol
how come no one asked if he did the transplant,you own a 1990 truck with a 6.0,a lot of opinions what the issue is and its not clear what he is working on.
I just figured he did the swap lol
Generally it does not matter when looking at why an engine is overheating. It is a very simple system, that has some pretty common causes to look at first. I stand by the general way to avoid air locks in cooling systems. Mechanics that work in non dealer garages do not have access to brand specific service manuals, so they learn ways that work for them. Concepts are the same regardless of brand. Air locks are a pain the ass to get around. The big trick is that air trapped above the opening has to be helped out. If the cooling systems were actual direct paths, with positive displacement pumps, it would be a lot easier to bleed air out of them.
Generally is the key word here.These trucks dont have air lock problems like some cars do.bleeding air out of these is simple
I asked if it was a transplant ,which we still dont know.
what if its is a transplant and it has cooling fans that are wired wrong and spinning the wrong direction?
the more info the better...like if its a swap
I don't remember a 366 in anything back then, so I'd have to say YES to the swap ....
I've also never had an issue getting air out of these engines. Usually just squeezing the hoses, and a heat cycle, gets it all out of there.
If the fans are wired wrong and spinning in wrong direction, it would only be an issue at the exact mph speed that matches the fans speed. Just like the 5th generation Honda VFR800 fans did. The fan on that bike spun in a direction that pulled air into engine area across the radiator mounted on the side of the fairing. At 10 to 15 mph the air flow coming in the front of the fairing was at approx. same speed as the air being pulled in from the side of the fairing, thus actually stalling airflow across the radiator. Pain in the ass in heavy traffic.
More info is always better, but, no need to not post suggestions that most likely will address his issue while waiting for an answer. I would think that if this has been overheating ever since he swapped the engine, that would have been stated in the original question. Air lock issues are more common than not. They generally work themselves out during the first full cycle of engine temp though.
OP has listed on his profile 99 2500
with that i would say he may have gave false/mistake info,likely not an engine swap.just a 99 3/4 ton 6.0 overheating.More info like how many miles and what may have been done to it most recently would be helpful
    • You must have that upgraded gvw package which is only available or at least was in 2025 with the diesel engine for the 3/4 ton and that gave the truck physically the larger 12.0 ring gear rear diff and the 3500 rear spring pack. There is a difference in what the diff housing looks like externally as one tell tale and also your truck should have the upper overload spring pack and the frame pads that the pack goes up against.    The pressure the tpms system kicks the alarm in on a stock setting truck, that is a good question and was just from what I recall but I doubt I made any notes on it as I knew for the rear that it was not at all what I was after regardless either. Being that you have a diesel and if running on stock tires the minimum pressure on an empty truck seems to be around 50 psi from hearing of those that have weighted the front axle but the rear axle is very similar in weight to a gas truck and again a near empty truck on the rear could go down to 35 pounds at minimum. However the weigh scale is the proper way to know for sure as a guide.    As to changing the readings on the dash from metric to the US measuring system, oh yes that is done easily but what I was attempting to explain was that I can't pick and choose items I want to have in US and those I still want in the metric system at the same time as its either all or none. For example lets say you drove into Canada and switched your dash over to metric so your speedometer read in km an hour, well then your reading kilopascals on your tpms readout and your wife looks over and says what the hell is that saying in the tpms screen and you say "darned if I know, I think its Chinese" !
    • This is partly why I decided to have switched over to Amsoil SS as a way of hopefully preventing the buildup of the sludge/carbon on the pistons and clogging of the oil control rings and the carbon that would cause the compression rings to stick in their grooves as well as stay cleaner up top of the heads in the valve train in the first place, an oil that has tested better by third party testing over typical shelf oil and also doing my best to run relatively short OCI. However in saying that I don't think there is any way to easily prove the oil I was using prior allowed for a buildup at the OCI I was doing, nor in the other direction to make claims the Amsoil is keeping everything clean either. There really isn't a window into the engine is there to know anything for certain even if oil samples were taken for example that showed still healthy oil being dropped out of the oil pan other than engine tear downs that extensive and expensive testing of oils does to actually visually see what is really going on inside the engine. I wish there was some easy method of seeing what is going on but I don't happen to be aware of that if there is.
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
