I have installed the suspension maxx level kit and installed 2.5" in front with the relocation bracket and it feels like it rides better than the day I picked it up out of the dealer!
Did you do install yourself?
I took to dealer only cause if I have any warranty issues they'll help me out with them installing it, but install looked very simple didn't have to take any part of the strut assembly apart it was just a spacers where it mounts
Meangreen
Can you post some pics of your truck with new kit on.? Also, I'm assuming you only did the front to get your truck level? I have a 2015 Sierra Denali 5.3L 4x4 CC. I'd like to get the front raised as close to level as possible
Sent from my SG Note 4 on Tapatalk
Just an update on the 4" fabtech kit. I re-calibrated the magneride sensors and shes riding like factory again!
Thanks for reporting back with your results! Question though..... How did you "recalibrate" the sensors? Did you lengthen the actuator extensions or did you re-zero the actuators electronically with a programmer?
Thanks,
Lou
Thanks,
Lou
I did it electronically. My business has a programming tool that the dealers use.
Sweet, Thanks!! I only want a 2.5" front level. I suppose then just about any good leveling kit would work and my dealer should be able to recalibrate for me. I like the suspensionMaxx Kit, just not too impressed with the plastic spacers that are included with it. Seems like they would wear prematurely. Your solution seems like the way to go!
Much appreciated,
Lou
Pics please
I've lurked around the forum the past 6 months looking for a way to level my '15 Denali w/ Magneride and the past few weeks have given me a reason to join and share some info in I case it helps anyone. Went outside one morning several weeks ago to find this
The police told me several other trucks were hit in my neighborhood, and we live in a decent place so my stock wheels/tires must have been on someone's shopping list. With insurance check in hand, it was time to lift. I had been planning on the 4" Fabtech lift kit (which called for 33" tires) as it was only one I had found that was Magneride compatible and had also found a set of Fuel wheels that my wife and I both liked. After working with a great local custom shop, we found out that my favorite wheels were 20x10 and would more than likely not work at all, or require major trimming, with the 4" kit - 20x9 are better suited. Not wanting to give up the Fuel Rampage wheels, I went all out with the Fabtech 6" kit and Nitto Terra Grappler G2 35x12.5 tires. Picked the finished project up a few days ago and was amazingly impressed...at first it seemed taller than you would expect a 6" lift to do (even with the additional height from the larger tires) but I am loving it after driving it around for a few days.
As others have noted in this thread, it will never drive/ride like it did when stock but I am impressed with how well it still rides with the larger tires and lift. Hopefully this might help someone to make a decision if you are on the fence....go big...you won't be sorry.attachicon.gif754A86D9-8F4D-4D1A-92D5-50B935EBE214:BBADCBE0-5FF7-424B-9DE9-8BB6DA3935AF.JPGattachicon.gif74F042DE-D829-4888-87FF-BEA63E4F0907:3BE76FC0-CC78-4248-8564-20A46E8DAD1D.JPG
Ran out of space for more pics...can add to another post if anyone is interested.
Wow that looks amazing! Karma at its best. Congrats! which fabtech did you get? Coilover?
-tapa
Edited by m3n00b
Meangreen
-tapa
I got the K1099, which i believe uses the coilover
Hey Johnstone,
When you did your 4" lift, were you able to re-position the ride sensors AND also did something electronically to relearn the shocks?
I've had mine back for a week now and although still not a bad ride, I'm wondering how to find out if my sensors are back in the optimal spot and if magneride is performing as it should. Any idea how to know if your sensors are in the correct position and not making the system think it is loaded and stiffening up?
Thanks,
Michael
Hey Johnstone,
Thanks,
Michael
Michael,
I did not reposition the sensors. I just re homed mine through the computer. Unless somone takes a pic of their stock sensor locations I dont think there is anyway of knowing.
For those of you who wanted to see my truck after the 4" fabtech kit... I apologize for it being very dirty... Chicago winter... yeah...
Johnstone
So your Fabtech 4" raised your front end level with the rear?
Johnstone
The back went up about 2 and the front went up about 4. So yes they are level now but a bit taller. You can stack the rear spacers together if you want to keep a high rear end.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
