There is still about 3/4" to 1" rake, depending on how much fuel in tank. I don't tow much, but I don't know how much tongue weight it would take to absorb that 1" rake. I had over 300 lbs behind the rear axle in the bed with 4 adults in the cab this weekend and it didn't budge. I "might" tow a motorcycle once every couple years, but that's about it so I didn't give too much concern to towing.
Hope my answer was useful in some way.
Regards,
Lou
Yes you did Lou. Thank you, and you have a very nice truck
Sent from my SG Note 4 on Tapatalk
Likewise! I actually like the color of yours better than mine. My 2014 Sierra was the WDT. Looks awesome and ALWAYS looks clean, even when it's dirty, LOL! This Iridium shows the pollen dust worse than black!
You went with the full 2.5" level option to make it even Lou? I ask because I have a 2015 Denali and am looking for this exact setup. I had been eyeing the 275/60R20 BFGs but if the 305s work on the stock rims I'll be looking at those.
Yes, I had them use all of upper spacers. I don't think it actually made a 2.5" difference. More like 2.38". It fluctuates depending on how much fuel is in tank.What I found interesting is the inconsistencies of fender heights in relation of front to rear and side to side. On the driver side, there's about a 0.75 - 1" rake and on passenger side is more like a .80 - 1.10" rake. Could be that I have more tools and equipment stored on the driver side of vehicle?
I've even noticed fender height inconsistencies between different brand new sierras while walking around the new car lots. Sometimes I measured 2WD Sierras with exact same wheels and tires measuring "higher" than some Z71 4WD Sierras? So many small factors and nuances make each truck sit and drive a little different.
The main reason I went with SuspensionMaxx is that is the only kit my dealer was comfortable installing, especially where the Magneride was concerned. I can tell the Magneride sensors are just right because the truck still holds level in the turns but also loosens up on straight smooth roads. I'm still experimenting with air pressure. Even thought these tires are pretty quiet for an All Terrain, I'm still trying to get used to the stiffer ride of such a heavy tire. I definitely have noticed a little power loss at take-off and a little more applied braking needed with the additional weight of these tires. The truck seems to have lost a little bit of its nimbleness. It's a trade-off I suppose of much better (tougher) looks and higher stance at the sacrifice of performance and comfort.
Didn't mean to rattle on...just my experience so far.
Edited because I think the dealership that installed the level kit may have filled my tank up with 87 octane fuel. The truck was empty when I brought it to them and full when I picked it up. I suppose they were trying to be nice. I won't know until I refuel but that may be why I'm noticing a sluggishness in the 6.2. Or it may just be from these new heavy tires. I'll report back
Regards,
Lou
Edited by Ten4Lou
Following up to my previous post... I had a chance fill up the tank with 93 octane this week and the truck pepped back up again. Not as peppy as it was before the bigger, heavier tires. But not as much power loss as I first experienced on the last tank. I'm convinced that the dealership filled up my tank with 87 octane last week.
That being said, there is still a noticeable performance loss with these heavier tires, just not as bad as I first thought.
Regards,
Lou
Edited by Ten4Lou
Thanks man, but you know I wish I would've waited for a darker color. I guess I like the way it pops off when she's all shined up...
I've got about 4,000 miles on my 2016 Sierra Denali with the Suspension Maxx level kit. Zero issues. It's on 20x9 with zero offset and 295/55/20 Toyo M/Ts. Also (in the last pic) I took the snow plow air dam off the front. Looks 10x better without it. IMO
Rides smooth just like the first day?
I am running the 2.5 suspensionmaxx kit and their 1" block in the rear on 285/55 20 ko2's
No rubbing and still has enough rake to tow.
Edited by Denali62
Rides exactly the same other than the difference with the tires.
So tires wise. The ride is a little rough, as in feeling the nobies?
Correct. Going from my Goodyear Eagle street tires to a M/T is a little bit different tread pattern. LOL. Still wouldn't change a thing though.
Thanks a lot. I have a 2015 Denali and can't wait to do this mod.... Nice job.
I installed the 2" suspension maxx kit and couldn't be happier. Don't feel any difference in ride quality.
Why did u only do the 2" instead of the full 2.5"?
Because I didn't want it fully level. I like a little bit of rake.
    • Google converting 98 4.3 spider injection to carburetor if all else fails.
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
