Hello, I'm not new to the forum but I just joined and figured I'd contribute to the community.
2016 Silverado 1500 "Z71" removed rancho's and swapped with Bilstein 5100's all around. So after doing a ton of research on this topic I decided to leave the Bilstien front struts at the factory setting and use a RC 2" (Lower Strut Spacer) to level my truck. Now before you say anything, I traded my 15 GMC Sierra 1500 Z71 in for this truck and I had put the Bilsteins on the front at the highest setting 1.77". After experiencing the ride with both leveling kits I honestly cannot tell the difference in the ride up front.
Here's my opinion on Bilsteins and the ride:
Positive: truck handles better in corners "not as much body roll" and bumps at high speeds you just glide over. I haven't taken the truck off the pavement yet but I'd bet you can take bumps and potholes at higher speeds with the Billy's. Installed the rears myself in the garage before I had the fronts done and noticed a little softer and smoother in the rear.
Negative: When you live in the city and drive under 45 mph you feel every bump in the road aka "Same as the ranchos."
Outcome: I believe that if you are truly looking for that Tahoe/Escalade/Denali ride out of these trucks with the stiffer Z71 pkg. than we need to look elsewhere. Does anyone or has anyone ever thought about changing out the front springs for an aftermarket "progressive rate coil spring" in these trucks? I have read info on the Fox 2.0/2.5's Icon & King coil-over replacements and I'm sure if you spend $800 + for these that they will no doubt make the truck ride softer on the pavement and off road. My question is instead of everyone worrying about shocks, I believe that changing the front springs out to a progressive rate coil spring with a softer spring rate is what would really impact how the truck rides/feels in the front. I have been looking into this and the only spring company I found that looks like it manufactures aftermarket replacement springs for our truck is moog. I have not found much info on the topic? Anyone else have any info on this topic please post. Lets get this figured out so we can enjoy our $$$ trucks that ride like a buckboard!!!!!
My truck rides the same way. I have 5100s on the front on third setting and stock black shocks on the rear that replaces the ranchos. I have 20 inch tires and I believe thats why I feel every little bump in the road at low speed 20 to 40 in town. Tar strips are the worst. When its times for tires going to look at going to 18s.
Good info to help clear any questions up...
6112
http://www.bilsteinus.com/uploads/tx_templavoila/BILSTEIN_B8_6112_Flyer_2016_WEB.pdf
5100
http://www.bilsteinus.com/uploads/tx_templavoila/BILSTEIN_B8_5100RHA_Flyer_2016_WEB.pdf
Also i see that Ram 1500 6112 are available for pre order!
Thanks for these links. Great info spelled out.. Says for the 6112 ride height for a GM pick up is 1.8" and the 5100s has a lift height if 1.85".
I was hoping to get a little more height out of these long awaited 6112s. So now I'm left with a spacer like kit......or risking a divorce after my wife sees the credit card statement after buying fox or kings .
My truck has the Z60 and was hoping to make it through this thread with something definitive that would make it ride a little better over rough pavement. There are a several places in the pavement of the roads, on my way to work, where the pavement overlaps and makes a line that rattles the whole truck.
I do like the idea of a spring rate change. I bet that would help most of the jarring that is occuring. It seems its mostly the front suspension that is stiffest to me.
I use my truck to mostly haul small loads a few times a summer. I pull a small lawn trailer around a few times a summer also. So I do not use mine as a truck as often as some. I do however put about 25k miles a year on it, so I do spend a lot of time in the truck would like it to be less jarring for me.
IMO good tires not the stock goodyears, air pressure 32-33, and 5100's on the lowest or one up from the lowest(which is where I have it) should make for a better ride at least it has for me.
I have a RC 2.5 level, with the included rear block installed. I'm thinking of going to a 3 inch rear block to get some rake. what rear Bilsteins would be best for my setup? thanks.
Thanks for the tip. I just got my annual bonus. If I have any left over I may look into a set of 5100. A new house and there are a few things that we need still so just maybe I can swing a set.
Is there a model of rear shock i need for a 4.5 zone lift? (2.75" higher in the rear than stock)
Sent from my SM-G935V using Tapatalk
Yes, we have one for you. With or with out resi? Is your truck equipped with the Z60?
Anyone know off-hand how much the GM front shock top hats cost? I'm wondering if you were to buy the top hats along with the 6112s, maybe the vendor could assemble them so they're ready for install when they arrive and won't require the buyer to either have a spring compressor or pay to have them assembled elsewhere. I'm wondering which would be cheaper, buying the top hats or paying shop labor. Around here, labor prices are pretty high.
Which is better, and what would be the price difference?
I have an LT, not sure if it has the z60, although i think its just the standard suspension. It has the zone hydro shocks from the 4.5" lift kit.
If the top hats are purchased along with the 6112s, will you assemble the units before shipping? At this point, assembled 6112s are the direction I'm leaning.
By the time the 6112 is released, our full service shop will be open. If so, then yes we can offer assembly.
Standard 5100 for zero lift, PN 33-238319 are the following.
Collapsed Length (IN): 16.18
Extended Length (IN): 25.79
Collapsed Length (MM): 411
Extended Length (MM): 655
Youll want one with an extended length of 4" or so longer
Go for PN 33-185569 (A Universal 5125)
Collapsed Length (IN): 17.91
Extended Length (IN): 29.7
Collapsed Length (MM): 455
Extended Length (MM): 754.5
or PN 24-067379 (Rear 4" shock for 99 1500)
Collapsed Length (IN): 17.28
Extended Length (IN): 28.29
Collapsed Length (MM): 439
Extended Length (MM): 718.5
Bilstien Universal 5160 with res (4" rear for 2500hd)
Part Number: 25-218206
Collapsed Length (IN): 18.17
Extended Length (IN): 31.26
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
