around $800 for the pair
Bilstein is late to the party.
The first introduction to these was back in 2015
Other vehicle kits are 650-700. I think once these are picked up at various places we will see a similar price.  Might take a month or so.
I've waited this long, I'll wait another couple of months to hopefully see lower prices. Everyday I'm shocked (sorry) at how poor the stock suspension is on my '15 SLT Max Tow 4x4.
AMAZING NEWS from BILSTEIN!!!
We have 130 sets of the new 6112 for the 14-18 Silverado and Sierra READY TO SHIP!! These will sell out by Saturday and be on backorder again for months! Dont miss out!
Our price is the best around!
GM-Trucks Members get yours here - http://battlebornoffroad.net/bilstein-new-products/bilstein-6112/47273702/i-7531506.aspx
SAVE $100!! Use code: GMTRUCKS
Edited by Battle Born Offroad
Right now you can get them for $600 shipped...
49 minutes ago, Yondu said:
Excited to read reviews of those going from 5100s to 6112s.
I noticed a big difference on my 2009, especially in the rough stuff! On road, there is less motion translated to the cab as the bigger shock is able to use less effort to control the bumps. I think on these heavier full size trucks, you really are best off with a 2.5" diameter shock or larger up front.
Which shock is recommended for the rear? I have a '15 Sierra Max Tow if it matters. 5160? I know it's in here somewhere but this is the downside of such a long thread. Thanks.
5160s or 5100s. 5160s are a tad longer and will allow you to run up to a 3" block, where as the 5100 is only good for a 2". Ride quality and valving is the same, but 5160s can take a bit more of a beating offroad without fading due to the reservoirs.
5160 Rear - 25-242515 - http://battlebornoffroad.net/bilstein/bilstein-truck-off-road-b8-5160-series-shocks/25242515/i-7476078.aspx
5100 Rear - 33-238319 - http://battlebornoffroad.net/bilstein/bilstein-truck-off-road-b8-5100-series-shocks/33238319/i-2157392.aspx
Be sure to add qty 2, and be sure to use the code: GMTRUCKS
So the block in the rear on the Rough Country 5" kit is a 3inch block. So do I need the 5160's ? I could've sworn I had seen tons of guys lifted who used the 5100's
If you are using the standard 0-1" 5100 for the 1500s and that block, you are limiting your travel by a bit. It will work, just realize the shock is being stressed at full droop pretty hard.
    • I find it amusing the OP doesn’t realize this threads heading includes several engines. He should have posted in the off topic section if he wanted a more narrow focus. I really appreciate and find amusing that he actually pointed out one of my many vehicles. The Odyssey. That happens to use 0-20 oil. I love pushing his buttons.
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
