Yea I think that makes sense. All the force goes through the shock/lower control arm instead of through the balljoint/upper control arm. Still not a good idea to hammer on the shocks that hard. It would probably wear out the seals and stuff early. Not that you ever do that much on the road.
I went with the Eibach leveling kit so I am at around 2.5in level so I definitely wanted to get some upgraded UCAs to help the angles. I don't think 1.8 inches is gonna hurt anything but I just don't like that the upper balljoint is held in by a piece of sheet metal on my truck. If I had the cast steel or aluminum I probably wouldn't have switched or waited until my baljoint was worn out to switch
On 2/16/2020 at 8:59 AM, Jdub289f said:
That’s good the hear! With my 5100s it felt more controlled but the stock coil doesn’t seem to be good at all. Almost like it’s maki  nag the shock do too much work. I’ll have to get the 6112 kit when my funds allow it. Should be an easy swap without having to align it since I already have the 5100 adjustables on there in the max height.
actually that's what you want if you have a good shock.....spring just supports the vehicle and shock is responsible for dampening, spring shouldn't get in the way of shock doing its job....if you have more dampening maybe can get away with lighter spring.....but yeah you want the shock doing most of the work....
Ok needing some help deciding. I have a 2014 Sierra crew cab 5.3L z71. Right now I have a 2" level in front that mounts under the strut (1" in thickness for 2" lift). Nothing in the rear. I have 275/70/18 on stock rims. No rub noticed on pavement or off road.
I have 1-1.25" of rake and I like the way the truck sits. But I want to change the shocks to either the bilstein 5100 or eibach pro truck sport. I'm keeping the stock springs and losing the spacer.
I know what the literature states for what sort of height increase to expect. But I'd like some real world #s. I've read this thread and some seem to be getting more lift than the reported #s. Please let me know your rake with this setup. Thanks!!
the eibach kit with eibach spring sits higher than same kit with stock spring....i believe its about 1" difference more lift....so when your reading stuff note whether its stock spring or eibach….both work on same kit.
Edited by Dunn
Yeah for sure, I'm talking about with stock springs. Just changing the shocks.
1 hour ago, BBinnj said:
not seeing that anymore- showing at $702.99 now...
Just checked. It is.
Well after as much reading as i could do on this Thread I've got everything set up to go on this month on the 26th.
Items are:
-6112 kit for front
-5160's rear
-Kryptonite UCA's (KRUCA13)
-Fuel Blitz 18x9 +1 offset
-275/70r18 Kenda RT
-1" Shackle for rear
-Zone trim plates
2018 Silverado w/ 13k miles
Items are:
-6112 kit for front
-5160's rear
-275/70r18 Kenda RT
-Zone trim plates
You likely won’t need the trim plates. I would hold off on installing them until you get the tires put on
I was planning on that originally but these tires run large for a 275/70r18 at 33.45x11.23. Plus i do plan on taking it offroad so just would rather remove any risk of rubbing at the same time as getting the rest done.
Quick picture after picking it up, will take more tomorrow: 6112’s and 5160’s
Looking forward to more pics? How did the trim plate install go?
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 442 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
