15 hours ago, Epsilon Plus said:
Do the 5100s have a "0" setting? I'm still trying to wrap my head around if they are for trucks WITH a level or can level themselves, or do both in combination.
I have a BDS 2" level that I am happy with. Truck sits perfect and drives fine. I have no interest at all in any extra added height, but I'm looking for some good shocks to tow with. The 4600s sound fine to me but they are for stock height apparently. That's fine for the rear, but again, I'm 2" higher up front. Does this imply that the 4600s would be too short and top out a ton with a 2" up front? Will the 5100s work in front for me without adding any more lift?
Since I'm here, how do the shocks lift anyway? Valve the fluid up and put all the pressure on an internal spacer/solenoid that provides the lift? I suppose I could delete the BDS and just do 5100 but I'd imagine the shocks would last longer if they weren't artificially trying to support the weight of the front end up. Maybe I have it all wrong?
Not looking to do any off-road. Just bought a max GVWR 7,000# travel trailer and looking for ideas to help keep it planted where it should be.
Thanks for any tips/info.
I have the 5100 shocks with a Rugged Off Road 2" spacer under the front strut.  I couldn't stand the Ranchos and didn't want to use the strut as the lift.  I'm happy with the setup and the ride is great.
To @Epsilon Plus
Coil-overs work by placing the shock inside the coil spring, but that coil spring has to have an attachment or "perch" location on the shock itself. The Bilstein 5100's have 4 settings. The lowest setting is "stock" height. Top setting is about 1.8 inches above stock.
If you have a lift that uses shims above or below your coilover unit, and you are using stock shocks, then you can simply change out your shocks with the 4600's or the 5100's set at the lowest perch setting. Most people get the 5100's INSTEAD of using shims, because the spring perch can be set higher. The shock fluid is not the cause of the lift, the fact that the coil spring sits higher on the shock is what is doing the work. Like choking up on a baseball bat. So for example, you could get rid of the BDS hardware at the front of your truck and just use the Bilstein 5100's at the top setting. Supposedly you will get a better ride quality as well.
I have the Bilstein 5100's on my truck and they ride great. Way better than the Ranchos that I took out of there.
I hope that helps
6 minutes ago, Grumpy Bear said:
Love your dog!
Thanks, Grump! Me too. One of the best dogs I've ever had. He's all "go, go, go!" and wants to be outside in the woods and mountains all the time "on the hunt."
I love Beagles but he wife doesn't like their bay. We have this 17"  33# Rat (Rex). Rare to hear him.
He is a perfect truck dog. Travels really well and nobody is getting in the truck he doesn't know.
Young man found that out trying to take my phone. Ops! Tinted glass LOL
Beautiful dog, Grumpy! I like the brindle coloring.
Here's Scout the Thundah Beagle at Mt. Washington this past weekend:
Scout will really only bay when he's on a hot scent or has visually acquired a rabbit. He will more traditionally bark if theres someone at the door or just outside the house though. Other than that he doesnt really make a noise for not reason, so if he barks or bays, I have to get up and look around to see what he sees.
On 8/5/2020 at 8:36 AM, ThundahBeagle said:
To @Epsilon Plus
I hope that helps
Both these help.
Thanks.
I finally completed my 6112 & 5160 upgrade and I am pretty blown away with how much it changed the dynamics of the truck. The OEM Ranchos felt like they were all spring and no shock and were just very bouncy in general. The 6112’s added needed composure over highway and off-road.
I don't drive a 2014+ but I have a 2011 Silverado with 275/55r20 stock wheels and I'm upgrading the suspension this coming month.  I'm awaiting quotes from 2 different shops.
Planning on 6112's in front at the 3rd setting and 5100 or 5160 in the rear.  My question is are people recommending UCA's for this?  I'd like to avoid spending the money if it's not needed.   I'll prob go with what the shop says, but I'd like to get opinions before I hear back.
Hello, good video,
 what rotors do you have?
How do the 5100's ride at 0 with a 2" spacer vs. no spacer but spring perch on the highest setting?
What would be better all around for me to do. I currently have a 2" motofab spacer but I'm only looking to clear 33's or a little bit bigger and am willing to not have exactly 2" and remove my motofab rear block and go back to stock.
I think you have a couple of points of confusion here. Or I am confused about your post, one or the other. Either way, this response should cover it:
Firstly, the front, adjustable Bilstein 5100's are not meant to be used with a spacer. There is no reason to place them at the lowest setting and then use a spacer. If you are going to do that, just put the Bilstein on a higher setting of your choice. Mine are all the way up (almost 2 inches) and I like it. I'm sure the stock setting would be nice as well.
Secondly, you mention removing the rear block. The 5100 fronts are adjustable, but the rears are not, so you could still use a rear block if you wanted to.
I would think that 33's would fit with 2 inches of lift. They tuck 33's under the Trail Boss. That has 2 inches of lift and people sometimes say the 33's look small on it. I dont say that, but some people do.
I hope this helps.
I hope this helps.
Yes, it does help somewhat! Thanks for the response. I know the rears are not adjustable, I had full 5100's on my tacoma. I just know that with the 2" spacer the front looked nose high, and with 1.85", I think if I went back to stock the truck might look similar. I only added the rear block because the 2" spacer up front was too much.
But thanks for clearing that up, if I want 5100's all around, then dont use the spacer. I'm worried because to use the 2" motofab spacer you have to cut some of the studs off on the shock mount. Hopefully there is still enough bolt to get the shock mount in with the spacer out, securely.
So, I read dozens of the pages on this thread - didn't find my question discussed ?
2017 Silverado High Country with 6.2L - I would like to "tighten" up the handling without raising, lowering, etc ... don't mind a bit harder ride, but really hate it when this things starts hanging in corners like on sharp interstate exits ...
I put Bilstein HDs on an older Ford SportTrac and it was an amazing difference ...
Thanks!
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
