Keddie's 2015 silverado fire chief truck
  • Replies 46
Hmm, if our city's chief ever saw this, he'd have one in the garage, ha. The FD definitely does have some nice stuff. I wish we had a pickup for our place, definitely more useful than the suv's that they get and then put large cargo bins in the back of.
I see nothing but problems with all those scotchloc connectors, they guy that invented them should be strung up. I do like the truck though.
Nice setup? If I may ask, what dept?
Sheridan fire dept........western NY
Ya they don't work well if the wire sizing isn't right.....I also put dielectric in them to help with weathering works great
I bought a trailer for my quads and after 1 year half the lights wouldn't work, that thing was chock full of scotchlocs so I ended up rewiring the thing from the tongue to the tail lights.
Looks great!!
nice..i would have rather soldered stuff.. thank crimps & quick disconnects...just me... on all my personal vehicles and tow trucks for business..stuff gets soldered....very nice tho..:)
You're livin the dream... :D
129771450_amazoncom-sad-face-deluxe-fire
...just ask me. My 2008 shortly after buying it.
I do installs on trucks I just finished a 2015 Silverado with a rumbler it turned out great
Hey man this is an amazing set up! Can you clue me in on how you wired those Step Lights? I have them on my truck and did not know you could get them wired like that. Also what type of LED Bar is that on your tail gate?
My brother is a volunteer with out local fire department and they just recently did up a chev bush truck (Mid 2000's I think). That came after responding to multiple grass and brush calls with most of the guys (including his chief) piling into my brothers dodge to get to the area. Awesome build man, Looks great and I'm sure will serve you well if you do many field and bush calls especially.
You need a rumbler siren...
Have that in the 04 haven't decided if I get another or swap it over.....not a cheap toy lol
The step lights work as tail/brake/reverse when reverse hits the red goes off so I wired the brakes to the trigger switch and the reverse to a flasher....hard to explain anymore
Just a eBay tailgate bar hooked up to a flasher
Just ordered the diablo trinity tuner
Exhaust and kicker sub finally installed
And work in progress wrapping the trim
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
