hey guys, thinking about installing a levelling kit on my 2014 all terrain, right now i have stock 20' wheels and tires. i can't decide between a bds 2'' or a RC 2.5'' I've heard many mixed reviews and was hoping you guys would fill me on on some of the pros and cons and maybe post your photos.
thanks
I have a Top Gun Customz 2" level and at first the ride was a bit stiffer but it was also a brand new truck. Now with 20k on it, I believe it rides and handles better than stock. So far not CV angle issues or tie rod issues
Rough Country also makes just a 2 inch as well. A shop I used to work for has installed countless Rough Country levels and had 0 issues. I run a RC 7 inch and have had 0 problems.
Edited by hemipowered22z
I thought about it and decided to spend the money on beer instead. Stock is alright with me.
  • Like 9
2.5" Rough country and I believe it really improved the look of my truck and I have zero perceived changes in function or drivability.
Rancho Quick Lift if your budget allows......
I now have the Rancho Quick Lift with RS9000XL adjustable shocks on both of my trucks and couldn't be happier.
I originally had the Rough Country 2" installed without issue. It seems to be the most popular and it doesn't cost much. It's also very to install compared to some other brands. It also doesn't require modification of any factory parts. You can either get the 2" bottom spacer or the 2.5" kit that also includes a small top spacer and rear blocks.
Sent from my crappy iPhone 6
using Tapatalk
what are the part numbers on the rancho quick lifts?
Front lift struts : RS999901
Rear Shocks : RS999198
I ordered mine through 4wheelParts, they had the best prices and Rancho was also offering a rebate.
using Tapatalk
2" RC level on mine. Picked it up for $20 on CraigsList and a $60 alignment at Pepboys has me at $80 total. I know this lift has been associated with ball joint issues but that's any lift and issues are mostly because people put bigger wider tires on with heavier wider wheels with a negative offset. Stay as close to stock as possible but 0 offset is ideal for less stress on suspension components. My tire size of choice to balance looks, fuel mileage and wear and tear will be around a 33-34" 10.50 tire (Currently eyeballing the Mickey ATZ)
Pro's-
Factory Ride
Truck looks the way it should have looked from the factory.
Room for bigger tires
Cons-
I need to buy bigger tires
Edited by TDT
Pro's-
Factory Ride
Cons-
It's because the angle of the ball joints/ tie rods that causes premature wear. Higher offset (lower numerically) can contribute to it do to the added leverage on the hub and such, but with only a level kit you can't fit anything much higher offset than a 0. Factory offset is +28 or so
2" in front for me. I think at times it looks nose high, I should have done the one in the back as well like the shop suggested or gone with 1.5" in the front.
I agree, the added angle doesnt help, but the amount in this 2" lift alone isn't going to decrease your suspension component life as much as many people lead you to believe. I ran a level with 285's on all my d-max 3500's and never changed a ball joint, tie rod components was another story, but the occasional 4wd launches with nasty tunes probably didn't help either.
i didn't realize these wheels had over an inch of +offset.
Bottom line... DO IT! Dealer isn't going to buy you ball joints if I'm wrong unless you can talk them into installing it for you.
Edited by TDT
Top is leveled with RC 2.5"with toyo MTs, bottom is stock.
If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance
Sent from my SM-G900V using Tapatalk
  • Like 6
    250.3k
    Head Scratcher
    Head Scratcher
  • Who's Online   4 Members, 0 Anonymous, 375 Guests (See full list)
