If you had 31" tires before, your speedometer will be off 6.4% and so will your MPG so.... 20.4mpg on a 19.2 display.
Impressive at 19.2 on a 33... 20+ is damn near amazing. I wish I could drive like an adult.
Remember that was highway miles mostly... With the cruise set and me and my Sirius/XM just riding & guiding.
Top is leveled with RC 2.5"with toyo MTs, bottom is stock.
If you take care of your vehicle, you will be fine. Who cares if you need to replace ball joints in 100k miles, that's part if maintenance
Sent from my SM-G900V using Tapatalk
As far as I'm concerned, the top pic is what an AT should look like from the factory.
Agreed, but I think you should take that front air dam off. It does just about nothing but reduce your ground clearance. I took mine off and have seen zero change in mpg, assuming that's what it's on there for. The front looks way better with it removed, IMHO.
That would be perfect if you are not going to use the truck for towing or hauling. The rear end is going to sag as designed when the truck is loaded or a trailer attached. Being just about perfectly level, when the truck takes that weight the front end is going to point to the sky.
Very nice looking truck just not an ideal setup for towing/hauling.
Sent from my crappy iPhone 6
using Tapatalk
using Tapatalk
I agree with this in part. I think the trucks that are leveled look great. I think GM is probably the most nose-low from the factory of any of the big 3. However, when I hooked up my 6,000 travel trailer to my Silverado, even with properly tensioned weight distribution bars hooked up, the back came down a little and the truck sits failry level when hooked up and gear the back of the truck for a camping trip.
If I had a leveling kit on my truck I have to believe the nose would be at least a little high, which is not ideal as it takes weight off the front axle which can adversely affect handling. Might be an issue, might not.
I still may do a small leveling kit someday in the future I did one on a 1989 K1500 Silverado I had years ago and loved what that did for the looks of the truck, just as you guys' leveled trucks look great. But if your towing or hauling heavy loads, just give it some thought first.
Just my .02 FWIW
Here it is.
I need to get better pictures.
No pics were uploaded :-(
Do i used the RC 2.5 level in the front and left the factory rear blocks on the truck.
Only if you want the front higher than the back!
Did you guys end up needing an alignment? I am thinking bigger tires so I might wait until I buy them.
You should have a front end alignment done whenever making changes to the front suspension.
using Tapatalk
I know its the right thing to do but if I decide to wait a month and get bigger tires will it really hurt?
nah, just wear out your tires quicker, if you wait a month, the odds are you'll probably get it done a couple months later...so i would do it now than later.
    • I have a 2015 Silverado and sometimes I can not get in to the truck. I use the key to unlock the driver door. Something is locking the truck when I unlock it, last night I left the truck open and this morning it was locked with the mirrors folded in. This happens while driving so it is now a safety issue. I reach down for the folding button and they open, then they close again.  Any advice, thank you,   Ed
    • Did you ever find a resolution to this? my 2019 Silverado 1500 is showing the exact same headlights issues with the exact same symptoms.  would help a ton if anyone has any advice on this or better yet a known solution..
    • tl; dr I've now reached the 6th floor of hell. I'm chronicling my journey for my morning readers.   Pulling the top of the intake apart was moderately easy but it involved a lot of parts, connections, and minutae. I was preparing for the new fuel lines to arrive ("nut and bolt kit" it's called). The fuel line connections are notched and held in place by the manifold and a metal plate with a T27 screw.   It's on the back of the intake, under the firewall, with little clearance, and two hard metal fuel lines in the way. I was using Franken-tools (weird combinations of 1/4 inch ratchet with/without an extension, with a bit holder for my T27) to get in there. One of my sockets and bits fell off and has yet to emerge on the floor. I lost a second setup and that's when I almost started throwing tools. But that was the point at which I had gotten traction on the Torx head, and it promptly stripped. No more traction.   I started humming "1-877-kars-4-kids" because I was about at that point. You know what? I'm $1500 into this thing and I can make it disappear just as quickly. This isn't fun anymore. I had spent a lot of time already "tidying" around the engine bay: Fixing all the "someone's been here before!" BS. The truck has been exclusively dealer- and shop- serviced and I'm reminded of why I never let other people work on my cars unless absolutely necessary.   Speaking of dealer service. This truck has a 1" stack of records going back to 1995. I put them all in an excel spreadsheet, date/mileage/description.   The CPI spider has been replaced 4 times in 85k miles. The EGR? Another 4. Multiple, multiple O2 sensors. One Cat. 4? Sets of plugs and wires, and I swear half the stack is diagnosis paperwork for "misfire, runs rough, extended crank, dies at stoplights".   GM was producing some proper crap back then. And it was still well within the era of brittle/crappy plastic. (Windows 95 was released the same month this truck was sold new, we HAD the technology!!)   There (was) a plastic shroud around the evaporator core and HVAC fan in the engine bay. I noticed a chunk of it missing so I poked at it some more and it literally shattered. Touched it some more and pieces were crumbling off. Had a good laugh. Clearly whatever plastic garbage they were using had broken down over 30 years and was literally turning to dust. That was a good half hour of using a shop vac to remove the rest of it.   Back to it.   I was going to give up for the evening but then decided I'm already level 10 pissed off at the stripped screw: G* D* it, give me my tools back -- and my JOY. We'll do this the hard way: The whole intake is coming off.   Blazer won Round II. After finally finding and accessing the 12 intake bolts and using a pry bar to unseat it from the heads, it popped loose in an explosion of gunk and grime raining down into open ports. Awesome.   6 times I reminded myself: Be careful of the temperature sender on the front of the intake.   YEAH, I forgot again and snapped it clean off in the removal. Add another $20 to the ever-growing list of new parts this thing is consuming.   The shame is, long before removing the intake, I had changed the oil in prep for Tuesday's momentous fuel line replacement that was going to be the magic fix and I'd have a running Blazer to tool around in this next weekend. The intake removal, including raining gunk, also gushed dirty coolant all over the valley. Of course it did. Welp, there goes another $35.   I now need an intake gasket set, bolt set, coolant temp sensor, another 5 quarts of oil, some RTV. Don't worry, I've already got 3 new jugs of Dexcool and a thermostat waiting. I'll fill it with clean water first to get it running, dump it, and then add the Dex later on in case... well, let's not go there. I'm only tearing this down once, next time the truck is going on Marketplace for FREE.   Oh, and I'm going to need vacuum hose for all the stupid connections placed at the rear of the engine which have since disintegrated. Come on, GM....tell me you don't do that anymore?   Oh, and the ears on the distributor where the cap screws down are both cracked. I mean, why not put a new distributor in it too. You get a distributor, YOU get a distributor, Everyone gets a new distributor!   This truck isn't out of the woods yet...I'm already questioning how much more time I'm willing to sink in.
