Need help on catback 2014 silverado
Logan1321
Hey I am new to this not sure where to post and haven't seen any help on this. Looking at borla type s exhaust, touring and then magniflow catback for 2014 Silverado. I am wondering is the type s is louder quieter or the same as the magniflow. The magniflow is the 18" muffler system number 15269.
I'd go to YouTube and see if you can find clips to compare.
Sent from my SM-G930V using Tapatalk
Have you considered Corsa Sport cat-back system. I have no knowledge on the Magnaflow. I looked at the Borla (GM parts) and found it to be a little too quiet for me. I purchased a Corsa Sport system from TDOT performance from Hamilton ON. The pricing was cheaper that getting it from Anything Auto or any US based website and converting to CND $$. I've ordered a few things from them, great customer service, great stock. Log or look at their website a few times and you might get a 5 or 10% coupon.
Until I installed the Flowmaster #817666 system on my '14 High Country, my experience with aftermarket truck exhaust systems was limited to a 2003 Silverado with a Flowmaster 40 dual system (3" inlet, dual 2.5" outlet with slash cuts out the back) and a 3" Borla system (Single 3" in/out with right rear side exit). The 3" Borla system and really toned it down to a mild growl from the bark of a Flowmaster 40 system.
I would say the 817666 system with Super 50 is the louder of the three systems I have had installed. That may be due to the side exits as I am hearing more.
I chose the Flowmaster system for the '14 Silverado due to price, configuration and sound experience from the 40-series system I had installed on my 2003. A Borla dual system was $300 more.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
