Will a 2012 6.0 work in my 2008?
I have a 2008 2500hd with the 6.0 and its has some miles and is a bit tired, also it sounds like it. Needs lifter or possibly cam. I have a newer 6.0 vin G with only 24,000 on it and I can't find anywhere that says straight up if it can be swapped without major changes?.
Well...the only difference that really comes to mind is the L96 G engine is E85 compatible, where the LY6 is not. They are 99% the same engine save for the E85 capability. Same heads, intakes, etc. Could there be a sensor you might have to swap over? Possible.
The only thing you'd probably have to really do is ditch the AC compressor if it has one on it, and put yours on it. The AC lines to it are different on 2011+up trucks, so your existing lines might not bolt up. Worst case, you might need a 2009-2010 compressor with the stretchy belt (use no AC belt tensioner) to put on there if there is nowhere to mount the AC belt tensioner off your 2008 engine.
Crank balancer 2008 and up are the same.
In 2010, the Vortec 6.0L V-8 VVT (L96) replaces the previous 6.0L engine with the LY6 engine code to reflect the addition of E85 FlexFuel capability. It also offers industry-leading cam-in-block variable valve timing technology.
The 6.0L L96 engine is offered in the Chevrolet Suburban HD and Silverado HD; and GMC Yukon XL and Sierra HD. It is also offered in the Chevrolet Express and GMC Savana full-size vans, and in the passenger and cargo models of these vans, its equipped with E85 Flex Fuel capability
The 6.0L L96 is from Gen IV small-block engine family. All engines in the family feature a market-leading balance of performance, sophistication, economy and durability.
Thanks man, I've just heard conflicting theories on whether it will work without changing cam,gear, timing cover etc or the ecm battle I would like to be %100 sure before I swap them. I have all a/c parts off donor truck
  • 2 years later...
Did you end up swapping it? I have similar scenario with dropping L96 in place of LY6. And unable to find anywhere if it's doable or not.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
