First time poster, long time reader. I am looking for some specific info, as I can't seem to find it thru hours of searching and reading. I have a 2016 double cab all terrain, 5.3, 3:42's, factory 20's. I am going with a 2.5" front leveling kit with 2" rear blocks. The front end is a combo of blistering 5100's set at the .75 setting, motofab upper 2" spacers, and diff drop kit. Rear is getting bilsteins, shock extensions, and 2" block kit. I am running the factory 20's with 285/65R20 Nitto Terra Grappler G2's. I haven't started anything as I want to have all the right components and get it done right the first time.
My question is - Can I run cognito uca's (ball joint as I am in the northeast) without tire rub? I know I may rub the sway bar. The cognito instructions say "larger tires will not work on factory wheels'". Isn't this one of the reasons for me uca's? Aftermarket wheels run almost the same offset to fit correctly in the 14+ trucks. Do you think the rub would be a lot? Could I possibly run a 1/4" wheel spacer and clear it? Any help and advice would be greatly appreciated. I really don't want to run uniball units, as I live in the salt region. I would like to eliminate the future wear and tear of the upper ball joints, and the possibility of failure.
Thank you
Rob
  • Replies 33
Per cognito
"In that case, typically no smaller than a 17” wheel…and backspacing allowances can change depending what diameter you plan to run. Most offerings in the aftermarket world will fall between 4.5” and 5.75”. We usually suggest no more than 5” of backspacing on a 9” wide wheel."
Also, why not just purchase longer shocks? Shock extensions aren't ideal.
At what point of the front end lift do you need to upgrade the UCA'S. I too plan to lift the front of my truck with Bilstein's at max height with 1/2" top spacer (should come out to 2.25 front lift)...Then add an additional 1.5 height in the rear for level towing.
Anything above 2 inches. If you plan on using your truck more than just on the street I would recommend it on any sort of level 2 inches or less as well.
Per cognito
Can anyone shine any light on the factory backspacing/offset of the 20's? Do you think I will clear any rubbing issue seeing I am larger than the 17" wheel?
I purchased the front and rear bilsteins for my previous 14 Silverado and planned on pulling out the lowering kit and going to a leveled truck. I sold the truck so I have had the shocks for about 6 months. I really didnt want to purchase new rears. I am only going up one inch in the rear, so I may not even need them at all.
Thank you for your help
I was told by cognito that you shouldn't have any problems until you get wider than 11.50 on a factory wheel. Any more than that there might be some slight rub on the control arm.
Excellent, I am wondering if running a 1" Bora Spacer would help the as well?
I honestly think you will not need it. The guy at cognito said he ran an 11.50 tire and never had any issues with rubbing on their control arms. I plan on running the same set up as you except with the 35x11.5 ridge grapplers. I actually have everything except the control arms and tires. Just bought a house so recouping some funds right now but I hope to get it all together soon. I was told I should be fine with that setup and if anything a .25" spacer may be needed but unlikely.
Excellent, thank you sir!
  • 3 weeks later...
Just an FYI, the factory 20" all terrain rims are contacting the front of the UCA's when turning at 80%. Full lock? Forget about it. Stock tires are clearing, but the rim is grinding the arm. I will get pics. Now I'm screwed
0f7e50fd056a09dc6c8d5aa3c9fb4992.jpge44c8895972328bc5badea4ef7f351b4.jpgd60965b676470de66faeb5f430d3a4d4.jpg
That's a factory 20? Did you take the picture while the truck was on a jack?
Factory 20, pictures on the ground as it sits in the other picture. This sucks
Have any other pictures? A top and front shot perhaps
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
    • Yeah, shame I can’t really get that filter easily anymore. Running a PureOne. Your fave!    TAN would be neat to see. Confirmation I ran it too long probably. 🤣
    • My son and I both bought new trucks in 2017. Both of us immediately put Truck Covers USA American Roll Covers on our trucks. My son still has his truck and it never sees the inside of a garage. We live in Alabama, so not much snow. My truck was my daily driver and was in the garage when I wasn't driving it or at work. No issues with either cover even after almost 9 years. About a year ago I sold my truck to my brother and bought a 2025 Silverado 2500. The second thing that I put on that truck was a new Truck Covers USA cover. They are very well made and have a very positive locking system. I looked at a Retrax and my concern was the way that the cover locked to the rail. BTW, the first thing I put on the new truck was step bars. Those new trucks are high!
    • The Allison 10 speed torque converter doesn't "lock up" like the previous transmissions. It has 4 operational modes; open, slip, transition from open to slip; transition from slip to open. I have an Edge CTS3 monitor and I monitor transmission torque converter slip. Step on the gas and you get a little slip. Take your foot off the gas and you get a little negative slip. I have not found a way to display the torque converter mode beyond that. My Edge CTS3 also displays something that our trucks should already display, the current gear. I also monitor throttle body position and engine load. If I see the engine load getting too high, I'll manually drop a gear.
    • Nice result. Your filter is working well  I'd have like to have seen the acid number for this sample. Curious type that I am.
