  • Replies 33
That's a 22 inch factory wheel +24 offset, but as you can see even if you follow the rim down 2 inches, it won't contact the UCA
Think you'd have any rub w/ a 18" factory wheel +24 offset? Exact setup I've been looking at.
Couldn't tell you for sure. I've seen a few build threads with this exact setup with both a factory 18 and 20 and this thread is the first mention of this kind of rubbing
