Yeah, Captain Hooks nightmare ... Tic Toc Tic Toc
If it is a lifter, what kind of lifters should I get for a 05 GMC 2500 HD with a 6.0 vortec?
This video shows whats goin on.
More to come as the information becomes available.
This engine has a bent pushrod most likely. Over rev can cause it. need to check them, spin and see if any others are touching head while you are in there .
Did the noise come on all of a sudden or did it gradually get louder and louder?
Is the engine still running smooth?
Any Codes?
My first thought was, it doesn't sound like a lifter. If you could use a stethoscope, that would nail the area down. If it's coming from a valve cover, it could be a bent push rod, collapsed lifter or even a broken rocker arm.
DEWFPO
All pressures are good, no loss of power, no other issues at all.
Parked it around noon runnning well. When I started it at 3 that same day the noise was there loud and clear and has not changed for about 3 weeks.
This is going to sound odd, but I had a similar situation occur with my Toyota FJ 4.0L V-6 but the noise wasn't quite as loud as yours but still very noticeable. No noise, then noise, but only when the engine was cold. It turned out to be the hydraulic tensioner on the timing chain. The noise eventually went away on it's own. That's why a stethoscope is a excellent idea to isolate the noise. There are a lot of moving parts in engine.
DEWFPO
I already ran for 120 miles with a quart and 3/4 of tranny fluid, and then changed that oil and it had not made a difference. Im gonna put some MMO through it today and see if that does not make a difference. If not, Ill go inside and see what I can find. The garage diagnosed it as a push rod as well. But then another inspector diagnosed it as a connecting rod. Wouldnt the noise be coming from way down low if it were a connecting rod? The noise does not come and go.
That noise will for sure give you a sick feeling in the pit of your stomach......... First thing that I would do would be to pull the serpentine belt just to make sure I do not have a belt tensioner / AC compressor /alternator etc mimicking a push rod click.
Tomorrow I will be checking the push rods to see if one of them is bent.
I am betting since I was running on 5/6 the amount of oil needed that one of the bearings is going. Gone I guess I should say.
Ill update you guys on what happens with the ol' push rods.
DEWFPO
I think I'll have to use a hose. Ill let you know what I hear. The cold temperatures caused it to come and go your saying?
A hose will work also, I've don't that when I didn't have a stethoscope available. It only made noise on cold startups but them quieted down after the engine warmed up. The noise lasted for about 4 months and gradually got quieter and quieter until it went away.
DEWFPO
I have never seen them so straight and so clean. The rocker arms are good and solid and all the push rods are a ok. Now I am trying to track down the specs for the rocker arm bolts and cover for the valves. Lookin like a spun bearing.
Did you check the lifters? I would check those, because that video you posted didn't sound like a spun bearing. I would expect a bearing to be more constant scraping. If not the lifters, then maybe a problem with a lobe on the cam.
I went in and checked the push rods on one side today.... all clear. Everything was good and clean in there too. I went ahead and sprayed some carb cleaner into the holes to get to the lifters. The rocker arms were all completely solid. no play at all.
I could be wrong but a spun bearing gives the connecting rod enough play to tap on its downstroke. The scrape noise is not really heard.
Tomorrow I am going to do the same check on the other cylinders on the other side too. If it is still tapping I may need some help figuring out how to get to the connecting rod's bearings and how to figure out which cylinders bearing needs to be replaced.
If a bearing has spun, it's not just a "replace the bearing" job. You also likely have to replace what it goes into.
IE, replace the rod, and then possibly also machine/replace the crankshaft.
And you want to figure out why it spun, it happened because something went wrong (like, say, it stopped getting oil).
Depends on the end use...if you want longevity and value, full rebuild; if you want to get a few miles out of it before it's scrap, emory cloth and a new bearing.
I've done that more than once (not that I'm proud of, but it got me or a friend by for a spell), I have even pulled a rod and piston from a cylinder with a hole through the block and ran that engine on five cylinders for a long time...I think that dozer is still going to this day.
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
