Rag Left in Oil Pan
Sorry, I'm not buying it...they would never tell a customer this...
Why would you think I would take the time to make up a story like this? Because I was tired of hearing about Russia in the news? I have a very close friend that owned the dealership prior to Berkshire Hathway buying him out. That is why I use this dealer and that is why they were honest with me about what happened. Since my friend is no longer involved with the dealership, I am concerned about what impact this may have in miles to come with my motor. Not making this up. My mangina isn't bothering me. I just have a 58,000 dollar truck that I have little confidence in now...
  • Replies 68
I wouldn't keep it pass the warranty. I would have ask for an extended on the engine.
I'd be pretty upset if this happened. What did your dealer do to help compensate for your inconvenience? They are not obligated to do more than " make you whole" again but sometimes they will add a free service or gift. A positive note was that they told you about their mistake. I doubt it was shredded or caused any potential future harm. They made a mistake and they were honest. I would not stop going to them just because of this experience.
Made a mistake I'll buy. But honest?
Another dealer screw up. Sorry dude. Good Luck.
No rag that I have seen has been eaten, deteriorated by engine oil. :happysad:
Eaten up by engine oil? To replace an oil pan gasket the oil pan has to be removed and unless you are talking about a Chrysler slant 6 with an externally removable oil pump, the oil pump and pickup screen is in the bottom end of the GM V engines. When you pull an oil pan there is a whole crap load of rotating parts, crank, camshaft, oil screen pickup, discharge valves, oil gallery drains and rough edges in the bottom end of an engine. A rag can float in oil for a hundred years and nothing will effect it ,but beat the crap out of it with a 50+ lb. spinning crankshaft with counterbalance weights spinning at over 2000+ rpms, wrapping it around the main bearings, beating it against the lower cylinder walls and piston rods, and it is soon ripped to shreds.
.02 The engine didn't lose oil pressure because the rag remained intact.
But then again someone stupid enough to leave a rag in a crankcase might be stupid enough to admit to it!
Well to be fair, oil pans are designed to hold their oil without the crank touching it, otherwise it aerates the oil. So we know there is space for 8 quarts of oil in there. It wouldn't be unreasonable for the rag to just sit there in the oil and then get sucked into the oil pickup, and just stay there causing a loss in pressure.
Would have been nice to see the rag
Agree. I was saying that the oil wouldn't eat it up or deteriorate it. :happysad:
I left my truck at the dealer for nearly 6 weeks awaiting the new condenser for the broken AC. While the truck was there I had asked them to investigate a small oil leak. They called to tell me the truck was ready and that the oil pan gasket had to be replaced. I was excited to get the truck back until I pulled out on the highway and a warning message popped up that said to shut off truck due to no oil pressure! I pulled in and got it back to the dealer service department assuming they had forgotten to put oil in it.
As we walked around the truck I saw a ding in my front fender that wasn't there when I dropped it off. We opened the hood to find both the brackets that run from the fenders to the radiator support were left hanging and....it had oil!!!
They just called me to say that the tech had left a rag in on the oil pump, but not to worry as the rag was in tact.
Holy Cow!! I'm worried. What are your thoughts? How worried should I be? Have 50,000 miles on this truck.
Wow.. that's unbelievable AND inexcusable...
I do agree with going to another dealership. Have them drop the oil pan, and then get an inspection camera into every passage, around rotating parts, etc. and see if they find anything. Good chance the engine life has been cut very short.
Good god what a bunch of Bozos at your dealership. Reminds me why I either do my own oil changes or a friend does them himself at his shop. I would probably offload it within the next 10-20K miles just for piece of mind.
When I got home I noticed the driver side had been rotated, but the passenger side tires were left untouched.
There is some type of evidence of a wheel having been removed and reinstalled? lol
OP post up an image of your work order stating a rag had been left in the oil pan then all these naysayers can buzz off.
Common sense I WOULD think...itsa Kali thing
Correct. It's called differences in tread wear on the front vs rear tires. Also, the right rear wheel had some minor grey overspray from the factory on the machined surface that was there when it was delivered to the dealer (all-terrain wheels). Pissed me off every time I noticed it while washing. That right rear wheel had not been moved, and by default, nor had the right front.
What was that you were saying about naysayers buzzing off?
I'll be happy to post the work order once they provide that and my truck back. I don't need tears. I don't need any additional comments from mental midgets. I just wanted honest opinions on how concerned I should be about any potential damage. For those of you that responded with your opinion on that topic, I thank you. For the the other no talent ass clowns, I hope you make another new member to the forum feel more welcome than you have me.
Don't assume you know more than the next guy...especially on-line. No one was crying or looking for sympathy, just looking for others with knowledge about these engines and what I might want to consider.
    • Diesel $5.42 at the truck stop on the hi-way
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
