Anyone noticed how cheap these trucks are to insure?
Who do you have? I have State Farm and am paying more than that
I have Stonewood Insurance, I don't know how popular they are but all other big known companies wanted an arm and a leg so I settled with them.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Yeah but the deer's rates usually go up since it's usually their fault anyway.
Haha
I went from a 14 Camry to a 16 Silverado and it was cheaper! Only by $20/year, but it was an msrp change of 20k. I couldn’t believe it.
I pay $554 every six months, but that includes a 1987 Fiero as the other car (just liability), as well as discounts for homeowner as well as safe driver and good student.
I'm also 25 years old.
$484 every 6 months. I have 3 cars and the house with the same company and have been with them for 25 years or more.
Damn, where do you live? On Long Island I'm paying almost $1300 every 6 months for my truck and my wife's Civic. I have my house with the same company as well (USAA)
I went from paying $1500+ per year under my parents plan in CT on a 2006 Passat to $900 for my 2016 in NH. My coverages are as high as they can be and my deductible is 500. I’m 25, have had a ticket or two, and the Passat is gone due to being totaled in an at fault accident.
I just paid mine and it was $372.18 for 6 months. State Farm, with another vehicle and house. No claims for me or the house through them.
That's for $1000 deductible, full coverage
In Louisiana, there's an attorney on every billboard. No cheap insurance here (for those of us that actually have it).
And this is why insurance of any type is so expensive for any type coverage.
Cheap?
Depends on your definition of cheap.
My 93 Silverado's liability was under $200 a year.
This truck, full coverage, $500 deductible, $800 a year.
2 houses, 2 vehicles and a boat.
:happysad:
2k yearly for 2015
Silverado 4x4 LT
Old Honda Element
And a
1968 Vespa
For my 2017 GMC Sierra SLE 4x4 I pay $138/month.
Before the truck I had a 2008 Jeep Grand Cherokee Overland diesel and I was paying $153/month.
2016 Silverado CCSB LTZ Z71: $329/6 months
2017 Tahoe LT: $320/6 months
Both have $500 deductible. Live in Iowa. Also have home and motorcycle with same company, American Family Insurance.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
