A ton of wood pellets in the bed of a 1/2 ton?
I usually get the wood pellets for my pellet stove delivered right to my driveway, but was thinking about buying a ton somewhere other than where I normally get them and just going to pick them up myself to save the delivery charge.
I have a 2017 Silverado 1500 double cab, 5.3, Z71 midnight.
Is a TON (pallet of 50 - 40lb bags) too much to be hauling in my bed? I don't want to overload the suspension. I'd be hauling the load about 14 miles.
  • Replies 32
Max payload is 2230 on that truck.  I say go for it.  Be sure the pallet is over the axle, strap it down and off you go.  I put close to 4800 in the bed of my 2009 2500HD before.  Truck didn't like it but it worked out OK.  Haven't tried the max on my 2015 yet though.
Cake walk. Just push the load as far forward to the front of the box as humanly possible, to get some of that weight on your front end to help with weight distribution, don't load it to the back of truck.
I did a well over a ton of tile and cement during my remodel. Truck was a little saggy but Lowe's is only a block from my house.
Sent from my SM-N910V using Tapatalk
This.
Not over the rear axle.
:happysad:
If you can't get the load far enough ahead to not overload the rear, you could do 2 trips.
Fro GM order guide, 2017 double cab payload rating
2wd - 1890 lb
4wd - 1840 lb
But these numbers only available when shared between the front and rear axle.
I've forklift loaded a bunch of pickups with bags on pallets and (as pointed out in posts above) getting the load far enough ahead was often a problem (since owners of newer trucks usually don't want the pallet slide on the bed floor)
Assuming your not hand bombing the bags , and depending on the forklift 'reach'  it might be helpful to take the tailgate off so the forktruck can get the pallet further in.
The truck will hold the load. just beware that you will either be riding on the bumper stops or very close. take it easy, especially over known bumps like railroad tracks. Plus it wouldn't hurt to make sure your tires are well inflated for the trip.
If you don't feel comfortable I say just rent out a Uhaul trailer and tow it.. but you should be ok having it on the bed...
^this. 19.95 to rent a 5x8 uhaul trailer if you dont want to pay the delivery charge.
Ditto, and when they ask what your going to haul tell them a mattress.  I have had Rental places tell me whatever is too heavy and they won't rent to me.  BS.
You are fine, I've hauled many tons with my 94 k1500 with 0 issues, wont have a issue with my 2017 i imagine.  my dad sells wood pellets you should see some of the vehicles we load 1 ton of pallets on lol. s10's, rangers, mini vans, etc
I say go for it, check my posts I’ve had a tote with close to 400 gallons of driveway sealer in the bed of mine and it was able to pull it fine.. it swayed a little in higher speeds and put me on the bump stops but it didn’t break anything so I say you’re fine. I have a 2016 rcsb 5.3/3.42 2wd
I use my 1/2 ton to haul many bulky items.  For the heavy, dirty or potentially damaging loads I use my 51 year old homemade utility  trailer.  If I didn't have this trailer, I wouldn't hesitate to rent a u-haul for such loads.
7 hours ago, Gary13 said:
Have a 2014, 1500. It tows a ton of pellets with no issue!
It better or you would be wise to get rid of it.  It should be able to tow several tons with relative ease.
    lanaderay
    lanaderay
  • Who's Online   3 Members, 0 Anonymous, 1,552 Guests (See full list)
    • Are you playing Slide Down endlessly but your score is still low? Are you constantly crashing into obstacles as the game speed increases? Don't worry, this article will share 5 invaluable tips to help you master the race and impress your friends. Golden Rules 1. Look one step further. The mistake of 90% of new players is only staring at their character. The secret of experts is to look towards the top of the screen (where the slide is about to appear). This gives your brain an extra 0.5 - 1 second to process the situation and determine the direction of movement before the obstacle approaches. 2. Use gentle movements; don't swipe too hard. Slide Down is very sensitive. Moving your finger too forcefully or with excessive amplitude will cause your character to be thrown off course or crash into a wall. Practise moving your finger with small, decisive, and precise movements. 3. Don't be greedy for gold in dangerous locations. Gold coins are tempting for buying skins, but life is more important. If you see a gold coin right on the edge of a cliff or next to a spike trap, ignore it. Our goal is a High Score, and your score only increases if you survive. 4. Make the most of Power-ups. During the slide, you'll encounter items like Magnets (attract gold) or Shields (temporary invincibility). Never miss them! Especially the Shield, it's your "get out of jail free card" to help you get through those deadly fast sections. 5. Stay calm when speed peaks. When your score exceeds 500 or 1000, the game speed will be very fast. At this point, don't try to think logically; let your natural reflexes work. Take deep breaths and don't panic. Apply these 5 tips to your next game, and your leaderboard will surely improve dramatically. Good luck climbing the Slide Down leaderboard!
    • If you use compressed air regularly, one problem you cannot ignore is moisture. Water in the air line can cause rust, unstable air pressure, poor tool performance, and even damage to sensitive equipment. That is why I highly recommend using a desiccant air dryer. A desiccant air dryer is designed to remove moisture from compressed air by using drying materials such as activated alumina or molecular sieve. Compared with basic water separators, it can achieve much lower dew points, making it especially useful for applications that require dry and stable air. For workshops, painting systems, pneumatic tools, CNC machines, laser cutting equipment, and industrial production lines, a desiccant air dryer can make a big difference. It helps protect equipment, improve air quality, reduce maintenance costs, and extend the service life of the whole compressed air system. Another advantage is reliability. Many desiccant air dryers are built for continuous operation and can maintain stable drying performance even in demanding environments. For users who care about long-term efficiency and equipment protection, this is a smart investment. When choosing a desiccant air dryer, I suggest paying attention to air flow capacity, working pressure, dew point performance, regeneration method, and maintenance requirements. A good model should match your compressor system and actual air consumption. Overall, if moisture is causing problems in your compressed air system, a desiccant air dryer is definitely worth considering. It is practical, efficient, and highly useful for anyone who needs clean, dry, and reliable compressed air.
    • My brand new 2007 Silverado's wax frame was rust from end to end partway through it's SECOND winter here in MA. That stuff is completely useless.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
