HI All,
I have a 2017 GMC Sierra 1500 Denali & have issues at time with Apple Carplay.  Sometimes it connects just fine while other times is doesn't.  When having connection issues, the carplay icon on the home screen will usually be there, but doesn't do anything when you touch it.  When having issues, text or call notifications don't appear on the infotainment screen but it'll still play messages or make calls when you press the voice command button on the steering wheel.
Could this be an issue with the phone or the infotainment system? "Sometimes if I turn my phone off & restart it before getting into the truck carplay will work fine.  However, it's a  50/50 chance that it'll connect again the next time I try.
Suggestions???
I have had problems with mine as well. I have had mine to the dealer and they replaced the HMI module i think. I still have issues and it is frustrating. Same thing happens to me. Sometimes it connects fine and the next time its crap. Sure would be nice if they would come up with a system that works.
I’ve also experienced intermittent issues with CarPlay, both with my 6s and now with my X. I don’t know if the issue is with the infotainment system or Apple’s software. I haven’t asked the dealer about it as I’m sure they would blame it on the phone.
I have found I can usually fix the issue by removing the USB cord and plugging it back in.
2017 Silverado exact same issue. Dealer says just unplug the USB and plug back in and it will work. The issue is this only works 50% of the time. Maybe a software issue?
Same iPhone 6s connects all the time in my kids 2016 Silverado with car play.
2017 Yukon Denali and I have the same issue. 50/50 here too. I unplug it and clear the phone then plug in and it works fine. I do find if I am using and app on the phone then try to make a call it gets confused. Meaning if connected to the truck it doesnt like doing two things which unconnected is not an issue.
of course today it decided to work just fine & didn't give me any problems.  yesterday couldn't get it to connect to save my life.
My 2017 Silverado does this as well, sometimes the projection icon stays there even though the phone is plugged in, sometimes the Apple car play icon shows up but it doesn’t work (although I’ve found if you click the audio button, Home, and then the Apple CarPlay button it will usually work), or sometimes it likes to start playing my music through the phone speakers. Definitely has some issues.
I have the same issue.  Usually when the CarPlay icon is visible on the home screen I can press the GM navigation button and let that come up for a second, then press the home button to go back to the home screen and the CarPlay Icon button will work.
For this reason, it sounds like it's a GM problem to me.
I was having some intermittent issues now and then. (iphone 5s) It has been working great for the last few months though.
Not sure if the new cable I bought helped, or an iOS update helped?
  • 11 months later...
I have had the same intermittent  issues with Apple Car Play connecting to my iPhone 8. I did find that a new cord seemed to help but still not 100% reliable. I have rented several cars and found Apple Car Play to work flawlessly in them. Does GM have a software update for myLink? I understand that such updates are supposed to pop up automatically when the truck is started but have never seen a notification.
On 1/14/2018 at 3:43 PM, steve76t said:
Suggestions???
Dump the iPhone and get an Android. I have had iPhones forany years (and my work phone is still an iPhone).  Apple used to "just work" but over the last several years the reliability has decreased at the same rate as their innovation.
Having the same problem with android auto works one day next day it doesnt use to shut truck off start it up and it would work now that doesnt work anymore.
I think it is a software/hardware problem. I had the same issue with my 17 Silverado. My new 18 LTZ doesn't have any connection problems. I use it every day as I travel a min of 4 hours a day in my truck
Tom
Hey all.
Anyone have any issues where when the phone is plugged in it charges, but Carplay does not come up at all? It has been spotty the last few months and now I don't have anything. Tried 5 different cables, All USB ports. Can't seem to find any solution or anyone with the same issue as myself.
    • I started with a folding cover by BAK PAC on my 2500. It went bad after close to 5 years. Bent and vinyl coming loose. Contacted BAK and they gave me a very good discount on a Revolver. Had it a number of years. Mostly outdoor storage. Some garage storage. Vinyl started to come loose. Still under warranty so they replaced to cover. Sold the 2500, bought the 1500 and got another revolver for it. Had it a couple years now and no issues. I store it indoors. Got a bit of discount when buying it as well. If you are seeing problems, contact BAK or real truck and let them know. Customer service was pretty good. But I think they changed their warranty.
    • Its possible you never had the joy of the crappy boat launches we tend to have around here or really some of them are just grades down to the river if its a river scenario and the conditions change all the time with the river levels and silt deposits. Some of the lakes we went to years ago, there was no such thing as a cement pad that went down into the water that the trailer stayed on, it was gravel maybe up to the water line and then duck crap much beyond that so sinking the boat tires into mud. Of course some of the more established lakes had a cement bar type boat ramp but sometimes it was covered in green slime closer and certainly within the water and a two wheel drive had all sorts of fun if one had to touch that slime with the rear tires.    A neighbor of mine had made a comment years back with his chev truck that was probably about the same year as yours but a half ton extended cab 4x4 and he a a fiberglass boat with an inboard so it wasn't a feather weight and he had gone out to one of the large popular lakes in the area and don't ask me how this happened but he was in two wheel drive as he figured he didn't require four wheel drive for that boat ramp and somehow upon pulling the boat out he twisted one of his drive axles. I suspect it must have spun and then grabbed on the cement ramp and shocked it to the degree of twisting it. He would have had the standard 8.5 or whatever it was axle housing as the 9.5 ring gear like my truck has also has larger drive axles as far as I know. Anyway he was feeling a vibration driving home and had it checked out and a shop found that the tire/hub was wobbling because of the axle had twisted so in went a new drive axle. After that bad experience he said he made sure to put it into four wheel drive to lower the stress on the rear axle. Of course that is where an HD truck can handle a lot more stress and no doubt these newer half tons with their larger ring gears probably have larger drive axles as well to match vs back in the day.
    • Desirable - as in does someone WANT one, aspire to have one. Could reasonably buy any car they want and CHOOSE these instead.    I didn't watch the video, why did they win?
    • The use of absolutes like "always" to describe gear selection, and giving free advice at a boat ramp sounds like a recipe for disaster. It's a boat ramp, not a farm, for starters.   IMO gear selection should depend on the obstacle. If low range is working and this is a slower speed, controlled ordeal, I'd keep using that.
