I finished replacing the seat heater elements on my driver seat over the weekend and wanted to post a bit of the process to replace them.  It took me less than 3 hours, including a break for dinner.  In my post under the topic Heated seats not working, page 14 I posted about my troubleshooting using PIT543A (Diagnostic Tips – Front Heated Seats).  In brief, I went through the troubleshooting steps and identified the problem as both of my heating elements that were impeding with too much resistance to function.  I have a 2014 Crew Cab SLT with Heated and Cooled seats and the safety seat vibrator.  The part numbers I ordered were 23170194 and 23223775.  They were perfect replacements, and I could also tell that there were some minor updates I could see from my originals.  Hopefully GM has fixed the garbage heaters that were installed originally and this time they’ll last a lot longer.  The heating pads have the cooling layer built-in to allow the seat venting to blow through the seat.  The heating element is covered by a felt material that sits right against the leather.  Under that is the layer for the ventilation material, which feels a lot like bubble wrap and allows the air to flow out through nickel sized holes spaced around the heating pad layer.  So contrary to some reports from dealers trying to explain poor performance, the heating element is directly against the leather… the venting layer is thus under the heating layer.  On to the actual work.
The first step to the repair was removing the seat.  Take the headrest off, it'll be easier to if you just get it out of the way right away.  Removing the rigid seat back is easy, and you can follow PI1091 for more info on that.  There are only 2 T50 bolts holding the seat in place.  Remove the plastic trim covering the seat tracks, and move the seat forward enough to get access to the bolts at the rear of the tracks.  With the trim removed, you can break the bolts loose and remove them.  I read this next tip online, but disconnect the negative battery lead before removing the big yellow and grey wire connector that you can now see with the trim removed.  That way you avoid potentially, yet unlikely, causing an air bag light to come on in your dash that your dealer would have to reset.  Slide the red safety tab back on the connector, then rotate the grey latch to disengage the connector.  This is the only connector going between the seat itself and the vehicle body.  At this point I took off all the seat trim I could get to.  The trim piece with the power seat controls has a hidden philips screw that is on the lower front of the seat that you have to get to from behind the trim.  Otherwise, all the other trim has visible screws.  Next, remove the seat belt anchor (another T50 bolt).  You'll have to take off another piece of seat trim covering the pretensioner assembly, and disconnect a wire that runs to the seat belt pretensioner trigger.  The pretensioner wire comes off by first prying up on the red safety tab, and then it just lifts straight off.
Edited by txab
(Step 2 continue)
You can now tilt the seat forward so it lifts out of the front slots, and then out of the truck, just be careful not to scratch your paint or interior with the seat rails.  With the seat out, it was pretty straight forward what needed to be removed.  I just started unclipping all the upholstery clips around the seat frame, unplugged the pigtails coming off the seat heater elements, and pulled the 2 haptic vibration motors out of the seat cushion.  The real challenge came when rolling the upholstery up and off the seat back.  The seat leather/vinyl material is held to the contours of the seat by these long blue plastic splines that are sewn into the seat material. These splines are clipped into the seat foam by orange pinch clips that are embedded and glued into the foam.  There's probably about 10 on the seat back that have to be unclipped.  I watched some YouTube videos on older trucks, and it was exactly the same process for mine.  You just have to carefully use your hand or a pry tool to unclip the spline.  I ended up breaking 2 of the clips, but when I was finished, it really made no difference to the appearance or feel of the seat.  For the seat back, I only folded the leather up high enough to get the heating pad off.  For the seat bottom, it was very easy to just remove the upholstery entirely.
The easy part was replacing the heating pads themselves.  The old ones came off with no problem, there is some adhesive that is used to hold them in place, but it won’t rip any of the foam when you remove the old pads.  The pads have a connection to the cooling blower vents integrated into them, and removing the old connection took some force and prying, but they eventually came off.  The new pads come with the adhesive backing covered by some wax paper.
So now everything just goes back on in reverse.  Again, dealing with upholstery splines and trying to pop them into their clips in the foam was the biggest pain, but nothing too complicated.  Everything else was easy from there on.  The clips that hold the upholstery to the seat frame are rugged and easy to deal with.  Also, I was a little worried about dealing with the air bag in the seat, but it was a non-event.  You don't mess with it or any clips for it and hardly even see it.
The good news is that my seat heaters are working great.  It costs $177 shipped to get the 2 pads, and it really wasn’t too much work to get it done.  If it wasn’t for the pinch clips and splines making things difficult, it would have been even easier.  So just watch some leather seat or katzkin replacement videos, but again, overall it wasn’t a big deal to do.  In all, the things I’d suggest needing to complete this are a multi-meter and back probe kit for diagnostic, a T50, T15, and Philips screwdriver, some blue Loctite, and a breaker bar helps a lot when loosening the seat bolts.  Thanks to this forum for helping get this taken care of!
(Pictures)
Driver's Seat with trim coming off
Driver Seat in vehicle
Rear of Driver's Seat with back pannel removed
Rear of driver's seat with back panel removed
Seat getting worked on
Seat Bottom with foam exposed and upholster folded back out of the way and old heating pads removed.  The splines fit into the channels in the foam and you can barely see the orange pinch clips.  The 6 orange stripes are from the old adhesive.
New seat back pad on left, old on right. This is the cooling layer facing up.
New seat cushion pad on left, old on right.  This is the heating pad layer facing up.
Edited by Jullian is not my name
Wow, well done! Saved a lot of money.
Just the thought of attempting this repair would seem daunting to me and probably would've motivated me to pay the dealer to fix it. But after reading this I think I might give it a 2nd thought if I needed to do this repair, or replace the upholstery down the road...
  • 8 months later...
Thank you for this guide, I changed out my heating element today. It took me about 1.5 hours. There is a YouTube video out there that was a huge help as well. It’s a shame you have to do this on such a new truck.
Do you have a link to that video? I would like to try replacing this pads myself. Did you also replaced the back rest element?
I just did the cushion element, not the back element. It should be just as easy to do the back, once the seat is out, should be easy to identify the clips for the back.
Thanks!
On 06/02/2018 at 7:45 AM, Jullian is not my name said:
(Pictures)
Hi, any tips on how to remove the seat back panel?
So the dealer recently replaced the bottom heater element in my 2016 GMC Yukon - the heater works now, but I feel the lane-alert haptic feedback vibrations while driving are now diminished  I am not sure if this is in my head, but I swear they were more prominent before the heater was replaced (I can barely feel the right side).  Could this just be in my head, or is there a real possibility that they somehow didn't replace these motors correctly when putting the seat back together?  Thoughts?  Thanks!
  • 9 months later...
Ordered my heating elements this morning. Thanks to this post I saw the slots for the haptic seat motors. I just dove in there and repaired both of my haptic seat motors. Posts like this is what this forum is all about.
  • 4 months later...
Did you ever end up finding out what the resistance of the elements were supposed to be?
I can’t remember the resistance but if you have infinite ohms then the heater is broken. The circuit is broke - it’s just a long wire.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
