On 5/24/2018 at 5:36 PM, Flflatsguy said:
3.5" Rough Country Suspension lift with 285/55/20 Toyo Open Country R/T
what is the offset of those factory wheels? are they 20x9s?
On 7/19/2018 at 10:25 AM, HeavyChevy90 said:
Like this look.  Sadly my 15' has 18's.  Not time for tires yet, but I want to do something more than the all terrains (looks more street to me) tires they put on stock.  Something more aggressive.  I'm torn with any lifting and screwing up warranty stuff.
I don't believe a lift or leveling kit would affect any sort of warranty because usually the bumper to bumper coverage is stuff that doesn't include wear and tear, ie: brakes, shocks, squeaks, bearings, etc. I run 34's and they rub at full lock slightly with the 2.5" level but I agree that the "meatier" tire does look better on trucks then the basic driving tire.
On 7/20/2018 at 9:01 AM, Denali34 said:
2.5" SuspensionMaxx leveling kit
I purchased the same leveling kit for my Denali.  I'll be installing it this weekend.  Just curious if you went with the full 2.5" level.  I'm considering starting the 2.0".    Any change in the ride quality?  Did you swap out your tires as well?
I used the full 2.5”. I put on 285/55R22 Tires. No ride quality difference. Make sure and get it aligned afterwards
Rough Country 2.5 level. Stock 20's with duratrac tires.
Will be replacing with TIS 544 wheels & fury 33"x12.5x20 this week! Waiting on delivery20180729_151914-01.jpeg
On 24/03/2018 at 5:13 PM, 2009GMC said:
Bilstein 5100 3rd notch for 1.5” of lift. Rear stock height. 38.5” front 40” rear. 1.5” rake vs 3” rake stock. 285/70R17 32.7” Bfg KO2 no rubbing. GMT900 N88 17” wheels.
Those 17's are awesome.  Relatively small diameter tire yet still looks beefy
CC standard box all the way!
Thanks! 17” wheels are smallest diameter that will fit on GMT900 and K2XX Generations.
Edited by 2009GMC
I found the identical gmc rims locally online
Would they still work for tpms? Not sure how old they are but they're identical to yours
I had my stock sensors moved over to the 17”.
The GMT 900 2007.5 - 2013 use a different TPMS sensor that’s NOT compatible with K2XX 2014 - 2018.
Post some before and after pics!
Guys asking 350 for them
I'd love to buy em but shouldn't right now lol
I’m toying with the idea of the same tire size but highway treads, but I only did the 1.5” Suspension Maxx on my Denali... Do you think it would clear? What’s the clearance like in yours? If not, I may get some strut spacers from SM and lift it the rest of the way just like you have.
Thanks
    daveishi
    daveishi
  • Who's Online   3 Members, 0 Anonymous, 1,406 Guests (See full list)
